Old 07-08-2003, 05:56 AM   #1
Default Futaba 3PK Question
I am thinking about purchasing this radio. For those of you that have one, are you running in HRS or PCM mode. Also, which servos should I be looking at. It seems that even in a digital setup people run a standard servo for throttle/brake. Is this correct.
jcrouse is offline   Reply With Quote
Old 07-08-2003, 06:40 AM   #2
I'm using mine in the regular PPM (FM) mode in the 75MHz band with a Novak Xxtra Rx and JR-Z590M servos in my NTC3.
In my XXX-NT I'm using it in the PCM mode with a JR-Z8450 steering servo and a Futaba 9405 throttle servo.
AreCee is offline   Reply With Quote
Old 07-08-2003, 09:42 AM   #3
InitialD's Avatar
jcrouse, I think you got it confused. If you want to use the 3PK in HRS mode with the R203HF receiver, you will not be able to use any analog type servos. You need to use digital servos only, including the throttle servo.
In the normal PPM / PCM mode with the R123F receiver, you are able to run and mix both analog as well as digital servos.
Old 07-08-2003, 11:27 AM   #4
Fire's Avatar
yeah, as D said, you need digital servos in HRS mode using the R203HF receiver
and i am running the HRS mode
Fire is offline   Reply With Quote
Old 07-08-2003, 01:07 PM   #5
Default A little more
Thanks for the replies. I do understand how it works. WHen the mix servo tpyes the must be running in PCM mode. I believe this is what your trying to tell me. So...let me restate the question. If I purchase this controller which mode do you recommend that I use. Also, why if possible, to help educate me a little. Then, in that particular mode, which servos do you recommend that I use. Also why if possible. Thank you for the replies and I apologize for the confusion.
Old 07-08-2003, 01:11 PM   #6
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: A little more
Stick with PCM. This way you can use Analog/Analog, Analog/Digital, Digital/Digital. Using Digital Servo consumes more power out of your battery pack.
I use only KO servos for my r/c car.
In general I use: KO PDS-2143 Hi Speed Digital Servo for Steering and KO PS-2174 Hi Torque Servo for my Throttle.
Why? Well, because I have a great support from KO. Should anything go wrong w/ my servo, it will only take me half an hour to get it fixed.
cheers!
eddiethefish is offline   Reply With Quote
Old 07-08-2003, 02:04 PM   #7
Default Additional clarification
The 3PK will operate in any of the modes; PCM, PPM or HRS. It is the receiver that makes the difference, the 3PK is sold with either the 203 HRS receiver or the 113 PCM receiver. If you buy the one with the HRS receiver then you'll need to use only digital servos. The PCM receiver works with any servo. Both receivers can be programmed with the failsafe function.
Old 07-09-2003, 12:47 AM   #8
I use HRS receiver & 9451 servos in my nitro car and I can't say a bad word about it. 123iF receiver & 9451 servo in electric car, works good as well. I have also tried HRS in electric, no problems. So whatever you choose, it works, end of story.
I have to say that there is NO noticeable difference in radio response between normal FM and HRS receivers whatsoever. I'm not saying the difference is not there, but it is not noticeable. After all, we are talking small fractions of second here and human reaction/response time is a lot longer than radio response time anyway...
Failsafe with HRS does not seem to work quite as well as with PCM (small glitching can happen before it activates FS), but it's expectable (loss of PCM signal is much easier to detect). Still, it's way better than nothing (=normal FM), so the HRS stays in my nitro car. PCM would be the other option, but I don't have any PCM receivers.
I like the 9451 servos as well. Compared to older 9450 they are easier to rotate when they are powered off, so TRS works a lot better. Decent speed & torque, only drawback is the price.
olev is offline   Reply With Quote
Old 08-15-2003, 09:46 AM   #9
Baluga's Avatar
Default subtrim
Hi,
Assuming you had the servo menu shows all channels perfectly centered. Is there any changes on the servo display when you set your steering subtrim +/- 100? I mean changes after making adjustment using the digital trim.
Baluga is offline   Reply With Quote
Old 09-06-2003, 04:25 PM   #10
Default 3PK TX Crystal
Hi,
I just purchased a Magnum 3PK with a 75MHz FP-PK-FM FM module. Anyone with this radio, how do I change the TX crystal for different channel operation? Thank you!!
soundfreak is offline   Reply With Quote
Old 09-06-2003, 06:14 PM   #11
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Default Re: 3PK TX Crystal
Originally posted by soundfreak
Hi,
Slide the top cover to the right and remove.....See those little clips holding the transmitter module in?...remove the module,and you'll see a little piece of metal on the module(its black)....take a screwdriver and gently pry off the cover....theres the crystal..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-06-2003, 06:45 PM   #12
Default Re: Re: 3PK TX Crystal
Great, Thanks Fastharry!!
One more question. Once I pry off the small cover on the module, do I need to put it back or can I leave it off?
Old 09-06-2003, 07:03 PM   #13
fastharry™'s Avatar
in the GARBAGIO it goes...
Question about Futaba 3PK emulberry Radio and Electronics 1 12-10-2007 09:52 AM
Futaba 3pk question 22dasher Radio and Electronics 7 12-05-2007 08:15 PM
futaba 2pl question parnelli97 Electric On-Road 1 08-25-2007 11:10 AM
Futaba 3PK-S question??? norman2cycle Electric Off-Road 5 04-10-2007 07:34 AM
Futaba 3PK question jg727211 Electric Off-Road 10 12-10-2004 02:49 PM
