Old 03-12-2008, 06:58 PM   #16
keavze's Avatar
Originally Posted by razzor View Post
On the 2 speed shoes you have the grub screw that puts tension on the cam in the centre, this is what you use to adjust the gap. Make sure you put on some lock tite or super glue so when its set it wont get loose.
The outer screws with the springs are for adjusting the shift point so always adjuts the equally and not on one side only.
Put teh shoe in the 2 speed housing and turn the grub screw till the shoe just touches the housing then back off the grub screw so the shoe spins freely but with minimal gap.
Once this is done you can fine tune your 2nd gear change when running the car. You will notice teh gear change will be a lot smoother and quiter.
after adjusting the grub screws for minimium shoe gap to the housing; both pieces of the shoes will separate with a slight gap, is it ok?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-12-2008, 08:08 PM   #17
aussies1129's Avatar
Trader Rating: 74 (100%+)
I just use the grub screws to get a nice perfect fit into the housing,get it so it just does not fit then back the grub screws off and get that perfect fit adjust both tension screws the same and get the shoes with a gap of no more than 2mm when you pull the shoes apart with you fingers.then on the track adjust both your tension screws the same and set the engagement where you want.
good luck
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
★ Robinson and Kimbrough Pinion Gears and Spur Gears - All NEW! ★ All-Star R/C Items: For Sale/Trade 40 01-21-2009 02:59 PM
WTB: Rc10t4 Spur Gears, And Pinion Gears Associated-08 R/C Items: Wanted to Buy 0 03-10-2008 09:19 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 07:08 AM
tc3 spur gears dynamaxxed Electric On-Road 6 04-28-2005 03:53 AM
RW Spur gears PhatPat Electric On-Road 3 02-26-2005 10:54 AM
