Old 07-06-2003, 05:33 PM   #1
Talking Tc3 Won't Shift Please Help
hola everyone
I have a ntc3 and i just got it running. The only problem is, i can't get my 2 speed to shift. I have it on all of the stock settings, but the darn thing won't shift. I took it apart, and i couldn't see anything wrong. PLEASE HELP
cejota
Cejota is offline   Reply With Quote
Old 07-06-2003, 06:02 PM   #2
Send a message via AIM to Bobby Flack
Loosen the adjusting screwsa about one half a turn, it is the adjustmment that is on an angle. Stock is 3 1/2, I think. Make sure you remember which one you adjust, they are numbered, so that you don't do the same one twice.
Bobby Flack is offline   Reply With Quote
Old 07-06-2003, 06:17 PM   #3
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Check to make sure the balls are evenly pressing againt the flats on the shaft
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-06-2003, 08:40 PM   #4
spawn's Avatar
Default Re: Tc3 Won't Shift Please Help
Originally posted by Cejota
hola everyone
cejota
Check this site out!http://nitrotc3.net/ You should be able to feel the 2 speed change.
spawn is offline   Reply With Quote
Old 07-06-2003, 10:01 PM   #5
Send a message via AIM to Lythion
Getting that thing to shift was the biggest problem I had with the kit. Make sure that you deburr the shoes and look inside the screw holes to make sure there isn't anything that will bind up.
Lythion is offline   Reply With Quote
Old 07-06-2003, 10:11 PM   #6
thefuzzclub's Avatar
Rebuild the 2 speed housing
thefuzzclub is offline   Reply With Quote
Old 07-06-2003, 10:27 PM   #7
Registered User
Send a message via AIM to bbntc3
Back the 2 set screws on the 2speed out 1/2 to 3/4's turn from the stock setting. Make sure you adjust the right 2 set screws. Alot of non shifting 2speeds on the NTC3 I have seen was from not adjusting the right set screws.
bbntc3 is offline   Reply With Quote
T-MAXX WILL NOT SHIFT TMaxx-25 Monster Trucks 22 01-17-2008 09:17 PM
Question about - shift and + shift mojoman Rookie Zone 2 02-13-2006 05:51 AM
NTC3 Will not shift, Please HELP Smalls Nitro On-Road 2 08-09-2003 06:35 PM
Car Won't Shift! Brad Nitro On-Road 3 04-30-2003 09:33 PM
Wont Shift to second Yokomo_King Nitro On-Road 1 04-08-2003 09:39 AM
