Old 07-03-2003, 05:40 PM   #1
Default Starting engine
hello
i'm new to petrol car and know little about it. anyway i bought a second hand car (pureten world cup edition) and the tank doesnt come with a pump so i'm wandering if there's a way to start the car without buying a new tank ??
zoombie is offline   Reply With Quote
Old 07-03-2003, 05:46 PM   #2
supra528's Avatar
you will have to use a starter box... that gets the fuel into the engine and starts it... so thats a good idea too if you have a non pull start engine... cuz then thats the ONLY way to can start it... unless u have REALLY fast fingers to turn the flywheel
supra528 is offline   Reply With Quote
Old 07-03-2003, 05:57 PM   #3
its a pull start engine
someone suggest that i put my figure over the muffler and that should put the fuel into the engine when i pull it (i think)
Old 07-03-2003, 07:16 PM   #4
Im2lazy's Avatar
That way should work fine zoombie. You could also blow through the pressure line, which is a faster technique, but probably too gross for most. (or too much of a hassle). As soon as you can spring for one, I would suggest a starter box. Even my dad who has no idea how somehting like this works could tell some person asking him that a starter box is 10 times better than a pull start. Pull starts suck, big time.
Im2lazy is offline   Reply With Quote
Old 07-03-2003, 08:15 PM   #5
B
wait until it breaks
then u will pull until ur hand blisters
or if ur engine has low compression......ull be pullin until tomorrow
go buy a 2nd hand starter box if u haf to.
B is offline   Reply With Quote
Old 07-03-2003, 08:18 PM   #6
vones's Avatar
snap the fuel cap a few times n the fuel will go into the carb.
vones is offline   Reply With Quote
Old 07-04-2003, 05:57 PM   #7
does a starter box help in starting a low compression engine ??
BTW: does anyone knows what the optimal or recommended setting for the Kyosho GS11R ?
engine not starting? whitrzac Nitro Off-Road 5 06-27-2008 04:52 PM
engine not starting 32819toon Onroad Nitro Engine Zone 1 03-01-2007 01:45 AM
Starting Up engine shaun_dini Onroad Nitro Engine Zone 1 02-17-2007 07:45 PM
Need Help with starting up my engine! kmaheartless Rookie Zone 3 01-12-2007 11:41 PM
hpi rs4 3 engine starting srowell3 Nitro On-Road 9 01-09-2007 10:32 AM
