OS TZ12 Spec II & 2607 Pipe >
Old 03-08-2008, 09:33 AM
  #16
bboy's Avatar
Other than price, how would you compare this with the OS.12TZ 5port? I am thinking of getting this one but came across the Spec II...
What is the difference?
Thanks.
bboy is offline
Old 03-11-2008, 12:38 PM
  #17
RevMaxx's Avatar
Thanks.
os .12tz 5port = 1.62hp @ 34,400rpm
os .12tz specII = 1.70hp @ 35,000rpm
RevMaxx is offline
Old 06-10-2008, 06:02 AM
  #18
Default OS TZ Spec II & T1040 pipe
I recently ran at a national using the T1040 Pipe on the Spec II. I couldn't get the engine to rev through, and at about 100 degrees C it ran as if it was still very rich. I even Geared the shortest gear ratio possible (MTX 4) I ran 16T/21T Pinion with 60T/54T spurs, and about 61mm tyres. It only seemed to perform at temps over 100 degrees which I was concerned about. The engine is still new.
Is this caused by the incorrect pipe for the track. We also run 16% nitro.
rascal_2 is offline
Old 06-10-2008, 07:52 AM
  #19
Rick Vessell's Avatar
rascal,
110-115 C is fine, you will not hurt the engine. If it is still very new, it's very tight and won't want to rev. I have one that's coming up on two gallons now and it still sticks at TDC when it's cold! The 1040 pipe is what I use for most tracks with good power and runtime. What plug are you using? 16% fuel is fine, I run 20% in mine everywhere with a P7 plug unless it's very hot weather.
Rick Vessell is offline
Old 06-11-2008, 03:48 AM
  #20
I'm also using the P7. What gearing do you run.
rascal_2 is offline
Old 06-11-2008, 07:37 AM
  #21
rascal,
17/24 pinion, 59/53 spurs, 60mm rear tire. Adjust accordingly for larger tires to maintain the same rollout.
Good luck!
Socko
Old 08-25-2008, 07:00 AM
  #22
Mazda614's Avatar
Default OS Max .12 Spec 2 Tuned pipe
Give the Nova 2601 a go with a 7 fin header, great bottom end, works very well with the Spec II, good power, run time and runs cool.
Mazda614 is offline
Old 08-25-2008, 04:30 PM
  #23
freestyles's Avatar
Trader Rating: 14 (100%+)
Could you please elaborate what '7 fin header' means and how do i recognise how many fins my headers have????
I've never heard it before
freestyles is offline
Old 12-13-2008, 02:53 AM
  #24
bboy's Avatar
This sounds like a small difference. Is that correct, or am I missing sometihng?
bboy is offline
Old 12-13-2008, 04:58 AM
  #25
NiTrO BoOsTeR's Avatar
as u can see,
the os .12 TZ 5 port has 5 ports,
the .12 TZ specII has 3 ports.
some clubs and national events have rules about the number of ports, a Tz spec II will out perform any .12tz 5 port
NiTrO BoOsTeR is offline
Old 12-13-2008, 09:44 AM
  #26
bboy's Avatar
Is the difference really that noticeable? The comparison looks small for an extra $100+...
bboy is offline
Old 12-13-2008, 06:35 PM
  #27
freestyles's Avatar
skyline vr12+ is a good pipe aswell
Old 12-14-2008, 06:42 AM
  #28
s10dude's Avatar
yup ! i use it on mine....
s10dude is offline
Old 12-14-2008, 06:46 AM
  #29
s10dude's Avatar
3 port ...on road legal (ROAR )
5 port ..on road NOT (ROAR )
s10dude is offline
