Kyosho GX 15 Engine Problem
Hi
I’m having trouble starting my Kyosho GX15 Engine in a Kyosho Fazer, what happens is there is too much compression in the engine and the pull cord wont retract (or retract really slowly as the piston slowly goes up and down) I thought that the engine might have some sticky oil or gunk in it so I opened it up and cleaned the whole inside, I wasn’t able to take the main shaft out but I cleaned the piston and the pistol sleeve all that – re-oiled it up and reconstructed it continues to have the same problem.
When I remove the glow plug the piston moves normally, cord retracts acts like normal, soon as the glow plug is screwed back in, compression is really tight again.
I thought the piston was seized so I heated it up in the sleeve with a hairdryer till it was moving smoothly. Apart from that I’m at a total loss of what to do!
Any help would be greatly appreciated!
you have to break the engine in if it is new
The engine has already been broken in, Its developed this strange fault prior to it being run.
I just checked it now to try and get it started again, unscrewed the glow plug a bit to see if i could get it to turn over, it seems to ignite fuel fine but doesnt have the force to push the piston down and back up again. I can smell that fuel is being burnt and the exhaust makes a nitro running sound (just 'pop' not a continus pur)
Still a mystery to me as what the problem is!
Whats even more strange is that the engine inside wise is perfect. When the heatsink is off the engine runs up and down like a doddle, soon as the heatsink is re-applied the piston will move smoothly untill it reaches the top where is becomes slugish and almost trapped.
Cheers
maybe the sleeve is 'not round' anymore?
The piston makes a full rotation, The engine is fairly new i guess it just needs to be broken in a bit more?
There is a slight pop noise, like air being pushed somewhere.
I tried starting it up again today, no dice, unturned the glow plug a little too, engine still wouldnt tick over.
I'll try warming it up with a hair dryer tomorrow then try and start it up again.
Cheers
I took the whole engine apart and re-lubed it all up, seems like the piston movement inside is a lot smoother now,
Tried starting it up again checked that the sleeve was all aligned and whatnot, loosened the glowplug a little, installed igniter, sounds like fuel is being ignited but only ignites once, one time it did ignite twice (like a bur-bur noise) i guess the engine is just really new and needs to be really broken in, quite a bother to start though! i'll try again tomorrow
Thanks for your help its greatly appreciated!
If you get a little more run time, it could be that it's too lean. You would have to turn the low idle needle anti-clock wise to richen it up a bit.
Only turn it a small amount at a time. Eventually you will reach a point where it is too rich, and if it does run, it will be spitting out oil and fuel at the exhaust. One thought came to mind, have you got the flywheel on the motor?
It won't run without it!!
Cheers
