Old 02-10-2008, 08:08 PM   #1
Questions?? big foams
Whats the difference between shores on 1/8 road cars and what size axles do they fit sorry for noob questions ive made a drag car out of an old TAgt10 and hpi rs4 and need rims and tires that look like drag car tires and actualy get traction
Roadrash730 is offline   Reply With Quote
Old 02-10-2008, 11:58 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
1/8 scale foams are made for 12mm axles, have a starting diameter of about 78/79mm (rear tire) and the shores is giving the softness.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-11-2008, 06:31 AM   #3
could you give me a measurement from the hex to the inside of the tire?
and maybe the total width of the tire..
Dustin
Old 02-11-2008, 06:38 AM   #4
Again sorry for all the questions my LHS does not stock them so i dont have anything to go look at
Thanks Dustin
Old 02-11-2008, 05:40 PM   #5
1/8th scale wheels don't have an inside hex. They ride on a pin on the inside and a lever snaps them in on the outside. They are completely incompatible with a 1/10th scale without major modifications.
You might think a wider tire will give you better traction, but not always. You won't do very well with a 1/8th tire on either of those cars. The weight and the size of the tire will slow down your acceleration unless you are packing a lot of extra horsepower (a .12 engine doesn't have the hp to overcome this). You are better off lightening your car and using 30mm rear touring car tires.
darkangel is offline   Reply With Quote
Old 02-11-2008, 07:38 PM   #6
speedybill's Avatar
Trader Rating: 73 (100%+)
Thumbs up
I purchased [some time ago]
adapters to adapt 1/8 onroad foams to a NTC-3 & a HPI Super Nitro
name was 'Wolfgang" I believe
pretty cool stuff
Speedy
speedybill is offline   Reply With Quote
Old 02-11-2008, 09:18 PM   #7
thanks for the replys guess ill have to stick w/ what i have unless i can find those adapters. Just using old wore out hole shot tires now they get fairly good traction just not enough to pull the front wheels up.Not trying to race this thing just want to be able to pull a wheelie for a little while maybe i just need a bigger engine that will pullit up once its going!!!again thanks for the replys
Old 02-11-2008, 09:36 PM   #8
Rapid Roy's Avatar
You can try somthing like this. I think you'll need those wolfpack radical converters to run them though.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHMW7&P=7
edit, I just looked again and it looks like and 1/8 scale tire with a large offset.
Rapid Roy is offline   Reply With Quote
Old 02-12-2008, 09:31 AM   #9
Those look perfect. Thanks for the link!!!Ill order some and let ya'll know how they work.
Old 02-12-2008, 09:33 AM   #10
Ithink i can make just about anything work this thing is frankincar for sure ill try to post some pics when i get it done.
Old 02-12-2008, 09:35 AM   #11
any idea where to find the converters?
Old 02-19-2008, 01:27 PM   #12
Rapid Roy's Avatar
http://www.wolfpackradicals.com
** CHEAP ** Jaco Sedan Foams Jaco 1/12 Foams New in Package 20+ pairs rc36deuce R/C Items: For Sale/Trade 23 10-07-2008 06:47 PM
NEED FOAMS? Jaco 1/10 Sedan Foams for Sale.. Desolas R/C Items: For Sale/Trade 0 03-17-2008 09:47 PM
F.S 18 T BSR FOAMS MOUNTED AND 1/10 FOAMS NEW IN PACKAGES valleyraceway Oval, Larger Scales and More 2 12-16-2006 06:32 PM
F.S NEW 18T BSR FOAMS AND 1/10 COOPER TRUCK FOAMS valleyraceway R/C Items: For Sale/Trade 0 12-16-2006 11:54 AM
FS/FT- 21 pair of new Sedan foams for 1/8th foams, mod motors FS also.. cdelong R/C Items: For Sale/Trade 0 10-02-2004 07:14 PM
