Old 06-28-2003, 12:24 AM   #1
B
Default MTX-3 tweak
i haf a question for all MTX-3 owners
i am sure that someone has put his Mtx-3 on a tweak station before.
Is the car supposed to be perfectly balanced? or is there some unequall weigh distribution.
I just finished building a new MTx-3 with extreme care. However, when i put it on the tweak station, the car is "heavier" on the rear right and "heavier" on the front left. It is exactly the opposite?
i checked the manual and i built it right
anyone any suggestions to why this happens?
thanks
B is offline   Reply With Quote
Old 06-28-2003, 10:46 AM   #2
vones's Avatar
tweak is not much of an issue in a gas car....
vones is offline   Reply With Quote
Old 06-28-2003, 12:29 PM   #3
Send a message via AIM to Bobby Flack
If the right rear is heavy the left front will be also due to "Wedge". It is always corner to corner. The tweak station will not show you if one side of the car is heavy, just wedge. You can fix it by adjusting the spring collars, a little up on both corners
Bobby Flack is offline   Reply With Quote
Old 06-28-2003, 01:17 PM   #4
Isolate's Avatar
Yup i agree as someone told me that the amount of fuel always changes when u start to floor it....
Isolate is offline   Reply With Quote
Old 06-28-2003, 02:13 PM   #5
B
well, that is not quite true
look at all the 1/8th, 1/10th onroad cars, and even Kyosho v one r/rr
the fuel tank is centered, so the tweak will not change! think about it!
Old 06-28-2003, 02:35 PM   #6
Isolate's Avatar
i do agree for most cars it's like that...but if i'm not wrong...the fuel tank for the MTX 3 is not centralised....
Old 06-28-2003, 02:48 PM   #7
B
haha
that is right too!
Cheers!
Old 06-28-2003, 03:43 PM   #8
Isolate's Avatar
Post
haha
that is right too!
Cheers!
Old 06-28-2003, 11:55 PM   #9
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
TWEAK on nitro cars becomes very important when you start to run a one way. If your chassis is tweaked and you step on the brakes, the car will spin out regardless how much brake pressure you apply.
Can someone explain to me how to adjust tweak on say a MIP tweak board or a Speedmind board? I want to get one but i'm not sure how I would adjust the car.
Racing4Evo is offline   Reply With Quote
Old 06-29-2003, 02:31 AM   #10
Roger's Avatar
True, but why would you wanna hit the breaks using a one-way ???
Roger is offline   Reply With Quote
Old 06-29-2003, 11:25 AM   #11
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
To avoid someone crashing in front of you? ... maybe... I mean, if you want to, don't hit the brakes and hit him, no loss to me.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-29-2003, 11:34 AM   #12
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Hi TSR6,
Thought we are the no-break-use guy. Look at it.
eddiethefish is offline   Reply With Quote
Old 06-29-2003, 06:50 PM   #13
First, you can use brakes with a one-way, you just have to be going straight when you apply them, and, your tweak has to be pretty close. Tweak matters on gas cars. If your cars pushes turning one way and is loose turning the other it is a pretty good sign your tweak is off.
To set tweak with a tweak station is really easy, set the front on one end the rear on the other, make sure the car is centered and adjust the springs so that the end that pivots is level. Lets say the left rear is low, that means there is too much weight on that wheel and also the right front. Adjust the collar down on the right rear and left front and/or move the left rear and right front up. Depends what you want to do with ride height. If the car is low raise the corners and if it is high lower the opposite corners.
Tweak is independent from left or right weight but it will change on a car that has the fuel tank off center like a NTC3 so you may want to take an average and check it with the tank half full.
By the way, picking the car up from the middle doesn't show you tweak, it shows you droop, unless you are adjusting a pan car, such as 12th scale.
Ted Flack (not Bobby)
Old 06-29-2003, 08:20 PM   #14
vones's Avatar
Well, I guess it's a matter of personal opinions......where I race, some of the guys has this aradite like matter on there exhast stinger to prevent damage and I'm sure tat the tweak will be on 1 side....still they are the fast drivers....maybe to an extend whereby the car is still able to be control when in motion.
Old 06-29-2003, 10:50 PM   #15
RCTech Member #2
TSR6's Avatar
Originally posted by eddiethefish
Hi TSR6,
Whatever floats your boat I 'spose.
Personally, I like having the option of using the brakes should a car, track, marshall, or other object cross my path. Even if I should spin the car with the one-way, It's often better than slamming into the ''object'' and breaking crap. jmho
Troy
RCTech Member #2
Tweak XNXIXTXRXOX Nitro On-Road 5 07-11-2007 12:06 PM
Tweak! performula Nitro On-Road 9 05-10-2006 02:14 PM
Tape -vs- battery brace "To tweak or not to tweak is the question" dawgmeat Electric On-Road 37 11-17-2005 01:05 PM
To Tweak or not to Tweak? SupermaxxRich Nitro On-Road 11 02-11-2004 09:41 AM
What does it mean , TWEAK ? Fusion Australian Racing 4 08-07-2003 11:35 PM
