Old 03-26-2009, 02:05 PM   #496
Send a message via MSN to PMSorber
Originally Posted by C Verano View Post
I have never ran the body witout raising it but even raised I had good steering with it.
The raised body generates a diffuser effect and thereby more steering and overall downforce.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 03-27-2009, 05:28 AM   #497
But, Am I right to say that it also compromises the straight line speed?
backplate is offline   Reply With Quote
Old 03-27-2009, 07:39 AM   #498
A bit, we never noticed a big difference in topspeed. On the other side, topspeed is not important on a technical track.
@ConSult Trading
Old 03-27-2009, 09:32 AM   #499
HarryN's Avatar
Send a message via AIM to HarryN
I'm sorry to hijack this thread as it is about the Shephard, but how is raising the body in the rear able to create downforce for more steering? I would assume you would need more downforce in the front to help the front tires grip tighter and provide more steering.
Am I missing something here?
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 03-27-2009, 11:36 AM   #500
Josh Cyrul's Avatar
Harry - By raising the rear of the body you actually increase the angle of attack on the entire body, front is steeper, center, etc... It's not just raising the rear putting it higher into the air. It ends up moving the pressure center farther forward, thus more steering. Also, you raise the CG of the body more in the rear than the front which can cause it to lean and swing more generating more steering. Lower bite, more technical tracks we raise the rear and higher bite, more flowing tracks we lower the rear. I've never really noticed a top speed difference from raising/lowering the body but I've slightly noticed it from the trim strip size/height.
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 03-27-2009, 11:41 AM   #501
HarryN's Avatar
Huh, interestingly enough, it made perfect sense. However, the last question I have is, why do some people to stick an extra piece of Lexan at the rear when going for the same results? Basically they raise the rear tail to it captures more air. Are they going for more rear traction in this case? I know it sounds stupid, but I have always thought a higher nose or a body pushed foreward creates more downforce for the front, thus creating more grip and steering. By raising the rear, like you said, it is sacrificing a lower CG.
Old 03-27-2009, 02:50 PM   #502
That extra piece of lexan also has an other purpose, it prohibits disforming of the body at the rear bodymount. CG is important but sometimes helps with a better stability in corners due to raising or lowering.
@ConSult Trading
Old 03-28-2009, 04:51 AM   #503
Quick question please,
I am considering a Sheperd Velox, what type of wheel fit this car?
Will the xceed tyres fit ok?
JustinZac is offline   Reply With Quote
Old 03-28-2009, 05:18 AM   #504
All but Serpent. Xceed will only fit if it's Offset-2 (Mugen offset).
@ConSult Trading
Old 03-28-2009, 09:23 PM   #505
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Thanks for that little bit of knowledge josh.Makes alot of sense and very usefull.
sm1nts2escape is offline   Reply With Quote
Old 03-30-2009, 10:40 AM   #506
AddictedToRacin's Avatar
Can anyone tell me what parts are included in the 900002 conversion set?
AddictedToRacin is offline   Reply With Quote
Old 03-30-2009, 03:02 PM   #507
Josh Cyrul's Avatar
Addicted - '09 Chassis, '09 front and rear uprights w/long pivot balls (4), LCG rear bulkheads, 30g front chassis weight, carbon fiber rear shock mounts and '08 Euro rear hinge pin mounts.
Old 03-31-2009, 03:35 AM   #508
thx
Old 03-31-2009, 09:17 PM   #509
To add to what Josh said.
A couple of years ago I was involved in some full size car testing where we removed the rear spoiler and added a rear wing. You can probably figure out what kind of cars were being tested by the wing part.
We took the spoiler off and added a wing, when that was done the aero balance shifted almost 20% to the rear. The reason is because the negative pressure at the rear of the car was reduced by removing the spoiler. The higher rear negative pressure (with a spoiler) actually pulls more air from under the car which adds front downforce.
A 1/8th scale body does the same thing for two reasons, one is the rear negative pressure effect from the body acting like a spoiler and the other is more area for air to get out. You would think sticking that big thing up in the air would add rear but it adds more front by actually sucking the air out from under the car with the higher negative pressure at the rear and shifts the balance forward like Josh said above. The total is higher as well.
Long story but it was cool to see how all the aero stuff works. And how it does the exact same thing on R/C cars.
Ted Flack is offline   Reply With Quote
Old 03-31-2009, 11:43 PM   #510
asw7576's Avatar
Is it possible that too much rear downforce could result in understeering car ?
ACADEMY VELOX XT15S PerformanceRC Electric Off-Road 2 05-25-2010 02:48 PM
Team Shepperd Racing SPEED V2& Velox DirtRacer Nitro On-Road 2 11-16-2007 05:37 AM
