Old 03-17-2009, 09:52 AM   #481
new3's Avatar
Originally Posted by Slo-MTX4 View Post
Has anyone run the P909 body yet? How far forward did you mount it?
i mounted the body where the motor mount are mind turn out to be 23 mm over the front bumper. i also mount it like the xytech body. so i am use the new ybslow mounts on the back they work very well. along with the the old paris front body mounts. (short) in the front. they lift the body an about 2 mil over the stock body mounts. i also i have used the existing front body mount with using the high mugan mount on the back . yes it fits no mod
www.new3racing.com, OFNA, Mugan MRX5wc, www.speedshophobbies.com, western engineering, redline racing fuels,
new3 is offline   Reply With Quote
Old 03-17-2009, 05:41 PM   #482
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Thanks for that i ended up just mounting it in line with the front wheel arches, so will see how that goes.
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 03-17-2009, 10:08 PM   #483
C Verano's Avatar
For the 09 car we had really good results with the body 21mm in front of the front bumper and mounted flat on the rear body mounts.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 03-17-2009, 10:23 PM   #484
C Verano's Avatar
Originally Posted by sm1nts2escape View Post
Are they going to make a 09 conversion kit?
Yes, I believe the part number is 900002.
Old 03-17-2009, 11:49 PM   #485
Slo-MTX4's Avatar
How do you mean flat rear body mounts?
Old 03-18-2009, 01:32 AM   #486
Default rear body mount
which means we still have to modify the rear bodymounts like the zytec?
backplate is offline   Reply With Quote
Old 03-18-2009, 09:08 AM   #487
C Verano's Avatar
No...Just mount the body with the stock rear body mount. No need to raise the rear on the Protoform.
Old 03-18-2009, 02:18 PM   #488
For what shells would you raise the rear??
And could anyone confirm the order of the shock spring stiffness is for the velox please?
Is it :
Softest - White
- Light Blue
- Dark Blue
Hardest - Red
Thanks!
Ian C is offline   Reply With Quote
Old 03-18-2009, 03:37 PM   #489
C Verano's Avatar
Is it :
Softest - White
- Light Blue
- Dark Blue
Hardest - Red
Thanks!
I would only raise the rear of the Zytec...You have the springs in the correct order.
Old 03-18-2009, 08:42 PM   #490
lastsun's Avatar
do i need to raise hte rear for the new Blitz body?
Serpent 966 EVO / OS MAX
lastsun is offline   Reply With Quote
Old 03-19-2009, 02:39 AM   #491
Cool, thank you. Why are you raising the zytec? I assume you'll get more rear downforce, and drag, but when I ran it (not raised) I had understeer when coming from the collari body.
Old 03-19-2009, 10:06 AM   #492
C Verano's Avatar
Sorry but I've never tried the Blitz body..I've only run the Central, Zytec, and Protoform.
Old 03-19-2009, 10:10 AM   #493
C Verano's Avatar
I have never ran the body witout raising it but even raised I had good steering with it.
Old 03-26-2009, 11:46 AM   #494
C Verano's Avatar
Default NEW PARTS
http://www.redrc.net/2009/03/shepher...n-alu-pulleys/
Old 03-26-2009, 12:02 PM   #495
VIPMOTORSPORTS's Avatar
we can sure use that 20T pulley
Motonica-USA // Novarossi // TKO Bearings // Airtronics // Protoform
VIP Auto Group Inc.
VIPMOTORSPORTS is offline   Reply With Quote
ACADEMY VELOX XT15S PerformanceRC Electric Off-Road 2 05-25-2010 02:48 PM
Team Shepperd Racing SPEED V2& Velox DirtRacer Nitro On-Road 2 11-16-2007 05:37 AM
