Old 06-12-2008, 11:14 AM   #136
Suspended
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 06-12-2008, 09:35 PM   #137
kitracer's Avatar
first batch is out here in Hong Kong. We have a large but tight track and mostly is Serpent territory.
I saw Sheperd Team in Japan driving it against the Mugen territory and did equal lap time so can't go wrong
kitracer is offline   Reply With Quote
Old 06-15-2008, 02:47 PM   #138
Default brake spring
hey guys the spring that fits between the leaver for the brakes won't fit into the plastic slots so the spring is a little bent is this normal or did you have the dremel the plastic the the spring fits?
younghovaa is offline   Reply With Quote
Old 06-15-2008, 06:38 PM   #139
BIREL8's Avatar
The spring should fit in without modification.
Steven Jackson
KILLA BEEZ
SHEPHERD USA
DESOTO RACING
KOPROPO
BIREL8 is offline   Reply With Quote
Old 06-15-2008, 09:48 PM   #140
how long is the spring for the brake. maybe I have the one for the linkage there. i have the shortest one on the brake part of the servo and the long one on the throttle part of servo.
Old 06-16-2008, 05:23 PM   #141
BIREL8's Avatar
The brake spring will be silver.
Steven Jackson
KILLA BEEZ
SHEPHERD USA
DESOTO RACING
KOPROPO
Old 06-17-2008, 11:21 AM   #142
C Verano's Avatar
I've been running the car for the last couple weekends and I have to say that I'm pretty impressed with the car. It handles very well and the durability is great.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 06-17-2008, 11:24 AM   #143
YBSLOW's Avatar
C.Verano you have PM.
Brad
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-30-2008, 11:09 AM   #144
Trader Rating: 15 (100%+)
Default Velox
Just a quick note of thanks to Kurt and Dan for tossing a couple of Velox parts my way at the Byrons race.
jpeck is offline   Reply With Quote
Old 07-01-2008, 07:22 AM   #145
kitracer's Avatar
finally got to run the car today( thanks to the weather). This is my first 1/8
Everything went really well. Love all the Alloy parts and the brakes. I did not change any parts although I bought the mugen ball cups and ball ends but the originals, which have a lot of play, did not seem to have any affect on the car's handling.
The stock gear ratio worked well , most serpents here using 16 pinion. I may try that next week.
I think you can use Mugen Springs. I measured them in n outs are identical.
Anyone tried different clutch setup. I "heard" they are interchangable to the mugen too. I don't have them to try myself.
Old 07-01-2008, 07:40 AM   #146
C Verano's Avatar
I've been running a 16/20 with a 49/45. If you're looking for more bottom give it a try.
In regards to the clutches, I think the pin locations on the Shepherd flywheel are spaced further out.
Old 07-01-2008, 09:39 AM   #147
Suspended
you can use mugen clutch shoes it is the same.
Old 07-01-2008, 10:31 AM   #148
C Verano's Avatar
If you are using a Mugen shoe, you need to make the holes in the shoe bigger.
Old 07-01-2008, 10:35 AM   #149
Suspended
i have been using the yellow shoes, and they fit just fine without any modification.
Old 07-01-2008, 10:43 AM   #150
C Verano's Avatar
Then your clutch shoe is probably sticking on the pins.
ACADEMY VELOX XT15S PerformanceRC Electric Off-Road 2 05-25-2010 02:48 PM
Team Shepperd Racing SPEED V2& Velox DirtRacer Nitro On-Road 2 11-16-2007 05:37 AM
