Old 02-07-2008, 10:13 AM   #1
Default Wheel offset
WHat does zero and 2 degree offset mean when purchasing wheels?
92mnstanger is offline   Reply With Quote
Old 02-07-2008, 10:45 AM   #2
lil-bump's Avatar
Trader Rating: 83 (100%+)
Some cars are designed to use a 1,2 degree offset. What this does it changes the center point of the tire when looking at the width of the tire.
If you mount a 0 degree offset tire onto a car designed to use a 1 degee offset wheel,the wheel may rub on the inside near the rear upright. This also changes your track width when you use different offset wheels. Hope this helps. There is a graphic online somewhere that explains this much better than I did.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is online now   Reply With Quote
Old 02-07-2008, 06:12 PM   #3
rmdhawaii's Avatar
Hmmm... Is it this graphic?
http://www.rctech.net/forum/attachme...3&d=1144925672
rmdhawaii is offline   Reply With Quote
Old 02-07-2008, 06:37 PM   #4
MugenDrew's Avatar
Trader Rating: 30 (100%+)
And after the fitments issue is resolved its all about mechanical advantage on the contact patch...stupid traction circle.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 02-07-2008, 07:35 PM   #5
Can anybody explain the different between 0 and 2mm offset when the offset is in the wheel and when it's in the hex? the overall geometry is the same on the car, the only difference that I can think of is that over the long 30mm worth of wheel, the 2mm offset would be stronger and create the feeling of a stiffer wheel.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 02-07-2008, 07:43 PM   #6
lil-bump's Avatar
Originally Posted by rmdhawaii View Post
Bingo!!!
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-07-2008, 07:58 PM   #7
lil-bump's Avatar
Not sure what you are asking. but the offset is the position of the hex in relationship to the center of the tire just like the picture. I believe an offset wheel only purpose is to allow full suspension movement when cornering without the worry of the tire rubbing on any suspension parts. Just remember if you change to an offset wheel your track width will change also. Some cars where just designed to use an offset wheel (ie Mugen MTX-3)
Elliott Hart
Serpent America
Desoto Racing Team
Old 02-08-2008, 01:42 AM   #8
chippy's Avatar
Track widths are also be changed buy using different offset rims
Which also changes roll centers
this can also be used as a tuning aid
chippy is offline   Reply With Quote
Old 02-08-2008, 03:14 AM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
More offset with a same total trackwidth on the front will give more on power steer
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 02-08-2008, 05:11 AM   #10
Is that true if the offset is in the hex, or if it's in the suspension though. shortening the pivot balls will change your roll center which could give you that feeling.
I've had a kyosho team driver tell me that offset in the wheel or the hex feels different, but I can't seem to work out the geometry other than the wheel is just stiffer because of how wide it is.
Old 02-08-2008, 06:31 AM   #11
Roelof's Avatar
The offset on the frontwheels will give a more changing wheelbase in the corners, the outside wheels will get a longer wheelbase and the inner wheel a shorter.
Offset is always made on the axle with shims, thicker hexmounts or other wheels
Old 02-08-2008, 03:03 PM   #12
rmdhawaii's Avatar
On a RRR, it is really a number of factors. If you use zero offset rear wheels (only the rears have an offset), you need to turn out the piviot ball screws to make 200mm, which means you're moving out the entire hub assembly on each side by 2mm. But regardless of if you use zero offset or +2mm offset wheels, the wheels are still in the same position relative to the centerline of the car if the track width is 200mm.
Something also to think about is contact patch and camber relatvie to a zero offset and +2mm offset wheel. Which one has a greater contact patch when cornering relative to camber setting?
I wish someone could get the info straight from the guy that designed the RRR. I think a lot of people have some good educated guesses as to why the car was designed this way, but it would be good to hear it from the source.
wheel offset? joe of loath Electric On-Road 2 11-19-2007 03:11 PM
What is an offset wheel??? motomanpat Nitro Off-Road 2 09-12-2007 06:49 PM
Wheel Offset question. rcpilot Nitro On-Road 1 07-10-2003 10:48 PM
Wheel Offset... deeno_x Rookie Zone 2 09-18-2002 03:35 AM
