Old 02-07-2008, 08:27 AM   #16
jameslow's Avatar
how about is i use solid axle on the rear? will it helps?
Waiting!
jameslow is offline   Reply With Quote
Old 02-07-2008, 09:02 AM   #17
teamgp's Avatar
Noooooooooooooooooooooooooooooo!!!
Unless your drifting.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 02-07-2008, 11:12 AM   #18
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by robert maestrey View Post
Remeber traction is established thru chassis roll....if your lacking traction on one end of the car..then you should create more roll thru softer shock oils,springs or roll centers...you should be able to run 30000 with a soft chassis setup..also toe-in in the rear helps alot when it comes to you rear end being loose...I normally run my RRR with a stiffer rear then front to gain steering response...I would try running 500 oil 30000 diff stock springs try lowering roll center in the rear...also a lower rear roll center will help with tire wear..hope this helps
Robert Maestrey
Thanks for the tips and suggestions Robert. I will definitely try them out. Im going to try different things... Last thing im going to consider is getting a very fast power drill and compact so my pitman can change my rear tires during a main... But its the last thing i want to look at.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 02-07-2008, 11:48 AM   #19
mtveten's Avatar
Trader Rating: 27 (100%+)
Another thing you can do to reduce tire wear & fuel consumption is swap out the solid front for a 1-way. I know many will say the locked front is the way to go for low grip conditions but I have found that when the grip goes low the 1-way is usually faster.
The solid front although great in some conditions does have some trade offs. With the front wheels locked left to right your car will have less off power turn in and require stronger braking on entry but with extra low bite you may find the surface to simply not provide enough mechanical grip to be able to make make the car fast with minimal wheel spin under braking and hard acceleration. Another consideration with the locked front end is that you are always scrubbing one front wheel in the turn, since the your outside wheel cant rotate any faster than the inside you are always effective pushing a wheel through the turn griding away additional foam.
In low grip a 1-way can be benificial because you simple don't need to use as much throttle or brake power to get around the track quickly and this reduction of input can greatly reduce tire wear and improve fuel millage.
With your tires also make sure your rears are harder than your fronts, going too soft in the rear can cause your foams to glaze over and slip even more.
My local tracks is setup on a sealed parking lot with very little sugar water spray and maybe 50F on a good day when our season starts. In this condition I generally run 40R w/ a 38F tire, softer foams tend to gum up and loose grip. For tire brands I have had good success with Jaco, GQ, & GRP with mino setup changes between them.
To go fast in low bite set you car up for soft & smooth with minimal trigger input and you will be faster with less wear & better fuel millage.
Mark
mtveten is offline   Reply With Quote
Old 02-07-2008, 02:18 PM   #20
Thumbs up
Mark
Mark i could'nt have said it better myself !
p1pioneer is offline   Reply With Quote
Old 02-07-2008, 06:48 PM   #21
Riketsu's Avatar
Mark
Man, I have tried not so many times to run with one-way... But I have failed miserably. But I'll give it a try. What do you guys suggest I should change in my setup when switching from a solid axle to one-way? Like, go softer in shock, lower rear roll center and higher front roll center...
Old 02-07-2008, 07:18 PM   #22
robert maestrey's Avatar
unless your running on a high bite track with minimal brake usage and high flowing turns I wouldnt recommned it..imo Hope this helps
Sippin Coladas and Chillin
robert maestrey is offline   Reply With Quote
Old 02-07-2008, 07:28 PM   #23
teamgp's Avatar
Yep. A front diff with relatively light oil would be a better compromise.
Guy Hood
Old 02-08-2008, 12:07 AM   #24
Seisick's Avatar
Problem with the tracks over here, the traction is close to none. By going to 20k or 30k, I'll be sliding all over the track.
want vht traction without high prirce, try some MELAZA, spanish for honey made from sugar cane, gives you way crazy traction, so much that your shoes stick to the track, how about 2.5mm wear on a 45 minute main with 40 shores, i usually try 42 front 45 rear to keep even the split on my car.
the mixing is 1 to 1 and we apply it with a blower such as stihl, the cost is around $8 and gives you for 3 uses on a 700 feet and 3mm wide track
happy racing
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 02-08-2008, 01:00 AM   #25
asw7576's Avatar
Higher Roll Center ( lower susp. hinge pins at higher level ) help reduce rear tire wear, but not that much.
When grip is lousy, the tires skid sideways too much. You need to sugar water the track, or re-coat the asphalt. Perhaps your hometrack asphalt condition need renovation when everybody start complaining about tire wear.
Old 02-08-2008, 03:17 AM   #26
Riketsu's Avatar
Yep... they are doing just that as we speak. . Problem is, that aint the only track over here. We also race in 2 parking lots which tire wear is a problem.
Old 02-08-2008, 03:18 AM   #27
Riketsu's Avatar
Yeah... thats why I haven't tried it. The only person I have seen running a one-way with success was when Art Carbonell visited us. And I think thats because hes used to it.
Old 02-08-2008, 11:21 AM   #28
duneland's Avatar
Race every OTHER week! Tires last twice as long.
duneland is offline   Reply With Quote
Old 02-08-2008, 10:36 PM   #29
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
After driving mainly 8th onroad I stepped down to driving the MTX4. Being that the car was so easy to drive it was time to push it to the limits and doing so also had me burning up foams. At the time 35 shores were used, but upon trying 40 shore traction was just as good and sometimes even better. No matter what shore though after changing my driving style they did last longer and I only go through two sets for the day of practicing/racing. I even run 40shore in the cool spring time, summer and fall with no traction issues really. Just thought I'd share my tips being I encountered the same issue.
HarKonnenD is offline   Reply With Quote
Funky tire wear... JEMCIV Electric On-Road 26 05-21-2007 06:59 AM
Tire wear RKeasler Electric On-Road 1 09-02-2006 06:30 PM
Tire wear questions tl-01-jhb Rookie Zone 8 12-01-2004 06:22 PM
Tire wear and tuning... rpnick Rookie Zone 15 09-08-2003 01:19 AM
Tire wear question R_Andersen Electric On-Road 4 03-26-2002 11:19 AM
