Old 02-03-2008, 04:52 AM   #1
2fast4fusion's Avatar
Default FUSION DRAG
hi anyone/everyone, just want to know more about drag cars in RC nitro set up, im really keen to custom my schumacher fusion into full drag car and im around 60% do'in it. for start do you know where I can get some part for a drag rc? anyone who has done this project or similar, pls help! ill post some pics soon, thanks for your time!
2fast4fusion is offline   Reply With Quote
Old 02-03-2008, 06:47 AM   #2
LOW ET's Avatar
Trader Rating: 97 (100%+)
drag racing parts can be got at grand motorsports, team walbern, litespeed. their parts are for purpose built drag cars not a transformed one. i have two grand motorsports (electric and nitro) cars and the quality is top notch!
LOW ET is offline   Reply With Quote
Old 02-03-2008, 06:57 AM   #3
wizby's Avatar
I have drag raced a fusion in the bracket raceing class. Also a NTC3 and V-ONE-RR EVO. I had alot of trouble getting the car to launch straight until i tightened down the diffs until they were basiscly spools. Lock them down. Most cars are over geared for the 132 foot drag strip. The 3 speed in the fusion is useless. What parts do you want?
wizby is offline   Reply With Quote
Old 02-03-2008, 08:48 AM   #4
If you have a high output motor on your fusion and want some wider tires on the rear end to improve traction you might check with wolfpack radicals , he make adapters for the shumacher fusion so you can use 1/8 scale onroad tires.
nitrohead5300 is offline   Reply With Quote
Old 02-03-2008, 02:48 PM   #5
Default drags
do you have some websites for these parts
isuzuguy is offline   Reply With Quote
Old 02-03-2008, 03:05 PM   #6
Default thanks!
would you know the web site address on these, pls? by the way thanks heaps for your reply...
Old 02-03-2008, 04:10 PM   #7
LOW ET's Avatar
http://www.grandmotorsports.com/
http://www.teamwalbern.com/
http://www.litespeedengineering.com/
Old 02-03-2008, 04:26 PM   #8
Default thanks!
Originally Posted by wizby View Post
I have drag raced a fusion. I had alot of trouble getting the car to launch straight until i tightened down the diffs until they were basiscly spools. Lock them down. Most cars are over geared for the 132 foot drag strip. The 3 speed in the fusion is useless. What parts do you want?
good info; yes I have locked the diff before and yes it does go straight, you wer say'n about 3spd is useless but isn't better if you could modify the gears to make it change quickly? that what I did my friend.... Im using the low gear option and modify the transmission lock to lock the 2nd gear quicker then 3rd gear. it kinda help me take off the car quicker then hit second gear and quickly to 3rd.... I build my fusion as light as possible for drag but year later I smashed it, went straight to the wall. now im rebuilding it but im making it like full drag car with 3spd. I extend the chassis to make it 12" wheelbase and rear wheel drive only and fitting a serpent 1/8 wheels on it and custom shorten front suspension arms to make it narrow. but for now I need a short belt drive to suit for my diff. would you know by any chance where can I get a belt drive size of 270mm length with 90T in 5mm witdh ? or even closer? pls let me know if ever........
Old 02-03-2008, 04:36 PM   #9
Default thanks my friend!
long time no chat my friend, I've seen your username every forum site I go to. yeah I had my fusion drag and smashed it but now im fully rebuilding it for drag only and make it rear wheel drive and extended. ived done the 1/8 rear wheels as close as possible to the diff to take off hard and saight as possible. but now im kinda looking for a drive belt size 270mm length with 90T in 5mm with or just even closer, if you know anything pls let me know cos I need as soon as possible to get t is thing running. by the way what " wolfpack radicals " do my friend are they spare parts? how's your car?
Old 02-03-2008, 06:03 PM   #10
............................Here is a link to his website http://www.wolfpackradicals.com when you get to his website click on questions and tell him what you want. He has some aftermarket products for the Fusion. My car handles great and is very fast.
Old 02-03-2008, 06:37 PM   #11
Here is apicture of my Wolf Fusion
Old 02-04-2008, 09:27 PM   #12
does anyone know which boat pipe to use for a rc drag car? I heared couple of guys use the boat pipe for drag but don't know which one....
IF YOU CAN'T BEAT THEM, JOIN THEM !!!
www.filo.org.au
Old 02-04-2008, 09:42 PM   #13
LOW ET's Avatar
prather #9010 for .21 engines. you're probably better off just using a regular style pipe.
Old 02-05-2008, 03:50 PM   #14
where can I get this boat pipe? how long is do you think this pipe? can you post the site, if you don't mind? is it the boat pipe kinda good for mid/top end power?
www.filo.org.au
Old 02-18-2008, 06:31 PM   #15
ok, well what would be the best tuned pipe for NOVA MAX .21 for drag ? pls help!
www.filo.org.au
Fusion 21 F/S OnRoad-Racer R/C Items: For Sale/Trade 2 04-02-2005 10:09 PM
2 Fusion 1.18 packs! Highest battery Fusion Makes! BSchorr R/C Items: For Sale/Trade 6 02-28-2005 08:16 PM
fusion pack 1.178 w/423 r/t BMI RACING R/C Items: For Sale/Trade 7 06-29-2004 11:35 AM
Fusion 21 nitrohead5300 Nitro On-Road 13 06-26-2004 06:13 AM
Novak Fusion ESC sol44 R/C Items: For Sale/Trade 1 10-01-2003 09:46 PM
