Old 06-25-2003, 07:37 PM   #1
NTC3 Racer's Avatar
Default tires
I have a Ntc3 team version. I need new tires bad. I wasn't impressed with the prolines that came on it. If i can remember right, the treads on a real on road car are just for driving in the rain as a deflector. Since i don't drive my car in ther rain, should i just get a pair of slicks. You don't see a top fuel dragster with treads on their tires. Who makes a good slick? How much are they? I am also driving on a freshly paved road. I know there are many compounds and i don't know which one to use.
thanks
CJ DUDLEY
NTC3 Racer is offline   Reply With Quote
Old 06-25-2003, 07:48 PM   #2
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: tires
thanks
CJ DUDLEY
Why don't you try the foam tires. Save time and money, no?
eddiethefish is offline   Reply With Quote
Old 06-25-2003, 08:26 PM   #3
NTC3 Racer's Avatar
Well,
My r/c dealer says they won't grip to the pavement unless i spray grape soda all over the street, and i don't think my neighbors would approve. Will the foams grip on regular pavement.
Thanks,
CJ DUDLEY
Old 06-25-2003, 08:41 PM   #4
spitfire's Avatar
Send a message via AIM to spitfire Send a message via Yahoo to spitfire
foams will grip better than rubber tires
spitfire is offline   Reply With Quote
Old 06-25-2003, 08:42 PM   #5
Roger's Avatar
I would reccommend a set of team Sorex tires ( these tires are slicks ). Try the 36R compound with red or green hpi inserts for your NTC3. If your LHS doesn't have them, then try a set of slicks from HPI and get them in 24mm. Make sure that the durometer reading is above 28R ( They're usually on the HPI header card ). Im not sure the foams will not work unless the surface your driving on is cleaned and treated with a traction compound ( soda, VHT, etc...). Hope this helps.
Roger is offline   Reply With Quote
Old 06-25-2003, 09:00 PM   #6
Roger's Avatar
Very true, but in order for foams to work, the surface has to be treated. I think if you were to use foams on untreated pavement, then I would suggest getting a set of soft foams ( 30-35 shore ).
Old 06-26-2003, 08:58 AM   #7
jhigga15's Avatar
These may be a stupid question...But can you use TIRE WARMERS on foam tires and are tire warmers worth buying...
jhigga15 is offline   Reply With Quote
Old 06-26-2003, 09:05 AM   #8
jhigga15's Avatar
Can you use TIRE WARMERS on foam tires and are they a good investment if I want to race?
Thnaks
Old 06-26-2003, 09:07 AM   #9
jhigga15's Avatar
Sorry I sent that twice, my net cut off and I thought that it didnīt send
Old 06-26-2003, 04:19 PM   #10
I heard you don't need it, so save up your money to buy something else.
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
