Old 01-30-2008, 11:02 AM   #1
JRGTR's Avatar
Send a message via MSN to JRGTR
Default brake issue on Mtx-4 or Mtx-4R?
Hi,
I I am having trouble with brakes with my Mtx-4. when I start the main I have brakes for the first 5 or 7 mins. but I have to run the rest of the main with very very poor brakes. I have allways have this problem but I ran all 2007 season with this issue. now I start with the same issue I won the first race but I'll like to correct this and not have to slow the race rhitm. Any tip from the Mugen driver's or other brand experience drivers?
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 01-30-2008, 11:32 AM   #2
andyobaez's Avatar
Send a message via MSN to andyobaez Send a message via Yahoo to andyobaez
Since when you don't change the pads? I think that if you verify them regularly, they'll probbably work well. Also, if you install the ventilated disc brake of the MTX-4R, you can solve that issue.... It works better....
Andy BŠez, Puerto Rico
http://www.facebook.com/pitlanehobby
andyobaez is offline   Reply With Quote
Old 01-30-2008, 12:22 PM   #3
evostyle's Avatar
Trader Rating: 102 (98%+)
Hi JRGTR,
For the most consistent braking action use the thick Mugen brake disc (standard on the MTX4R) which will dissipate heat much quicker and the Mugen yellow teflon pads.
evostyle is offline   Reply With Quote
Old 01-30-2008, 12:27 PM   #4
Genesis's Avatar
andy. tienes pm
Genesis Motors - Genesis "Killer Voltz" - Brooklyn Hobbies - JNR Graphics - RB Products - Novak - Losi - JACO - KO Propo - Mugen - VISA, MC and CASH. Decal quote email [email protected]
Genesis is offline   Reply With Quote
Old 01-30-2008, 12:28 PM   #5
evostyle's Avatar
I've used this setup for a couple of years now with great success.
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
Old 01-30-2008, 12:49 PM   #6
JRGTR's Avatar
thanks Andy I'm thinking on what you told me last monday on the shop.I see every body agree with the ventilated disc.
Matrix tires
Old 01-30-2008, 12:50 PM   #7
andyobaez's Avatar
Originally Posted by Genesis View Post
andy. tienes pm
Hola Oscar, PM sent.
Old 01-30-2008, 01:06 PM   #8
andyobaez's Avatar
Don't think too much and get the part ASP.
And you should hear what Iím saying more frequently.
Old 01-30-2008, 03:29 PM   #9
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Hi,
Get some Kyosho Truggy brake pads... You'll be damn sure you dont see any brake fading during the main . They fit the RRR and MTX-4
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 01-30-2008, 03:37 PM   #10
lil-bump's Avatar
Trader Rating: 83 (100%+)
Make sure your receiver battery voltage can last the entire race. You may have a weak battery. Just some other things to check. Good luck!
Race you later...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-30-2008, 05:21 PM   #11
JayL's Avatar
sounds like your pads are getting fuel on them, try the mugen teflon ones. Sometimes for some reason this happens to me and I have learned to turn the atl dial on my transmitter up with my thumb while I drive. I alway tune the car so the brakes feel perfect at about 75% on the atl so I can move it up, using the knob on the car's linkage
JayL is offline   Reply With Quote
Old 01-30-2008, 06:21 PM   #12
JetMD's Avatar
I have a stock mtx-4 and noticed brake fade as well. I switched to the k-factory vented and slotted brake disc as well as the mugen yellow pads. No problem since then. Works very well.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 01-30-2008, 08:51 PM   #13
Default Brake Fade???????
A lot of brake fade is caused thru the servo's getting hot, the brake throttle is the hardest working servo and if you try a 10kg and up high speed you will find you will never ever get that problem.
Darryl
The_Keeper is offline   Reply With Quote
Old 01-30-2008, 10:11 PM   #14
asw7576's Avatar
Darryl
You should set EPA at the maximum brake position. Hopefully the maximum brake position won't make the car spin too easy. Without limiting the maximum EPA, you are wasting battery power or risking broken internal gear.
I don't use silicone tube to soften the initial braking effect. I use direct braking feel, but I set my EPA at the point where my car won't spin in middle cornering ( braking late ). I feel braking without silicone tubes produce consistency braking feeling through out the year. I'm using the coin type brake disc in my mtx4. I don't have braking problem for 30 minutes or 45 minutes racing. ( my problem is that my car becoming lousy to drive after 30 minutes. I have to ask my pitman to increase rear ride height, and that helps a bit ).
Throttle / Brake servo don't need fast response, some says it could choking the acceleration feel ( more air entering the carb faster than the fuel ).
Old 02-02-2008, 09:31 AM   #15
JRGTR's Avatar
parts installed ready to test!!!
Matrix tires
HELP!!! ESC Issue Chris__RC Electric Off-Road 6 08-31-2008 01:31 PM
DPD issue Racingfreak6 Electric On-Road 5 01-01-2007 09:56 AM
OS .12 5p issue Black_Widow Nitro On-Road 4 12-18-2006 10:19 AM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 10:10 PM
drag brake, brake and reverse imjonah Rookie Zone 3 07-24-2004 07:20 PM
