Old 01-28-2008, 05:05 AM   #1
musti72's Avatar
Default clutch spring adjust nut
hi guys Im thinking about clutch spring adjust nut, do you adjust it depending on the track, or does it have one right setup for every track?anyone uses this for clutch setup?im confused. also need help about spring hardness effect
thankss
musti72 is offline   Reply With Quote
Old 01-28-2008, 05:30 AM   #2
JRGTR's Avatar
Send a message via MSN to JRGTR
first, what car are u driving? you should check in the manual the spec's depending on the track and the way you want the aceleration feel of your car you can adjust using your manual clutch spec's as reference.
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 01-28-2008, 05:35 AM   #3
musti72's Avatar
im driving the mtx4 and there is no informaton about that in the manual
Old 01-28-2008, 07:02 AM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
It's in the book on pg 20 step 46. The adjustment should between .6-1.0 mm depending on traction conditions. Hope this helps.
Race you later.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-28-2008, 07:11 AM   #5
JRGTR's Avatar
I also drive a Mugen check the page 20 of the manual the adjust of the spring nut of the clutch is .6mm to 1.0mm the soft piont is .6mm and the hard adjustment is 1.0mm my choice is .7mm and some times .85mm. the best way to find your best choice is testing all the setups on the most over all track so you can document the best setting to choose. hope this can help you.
Matrix tires
Old 01-28-2008, 08:21 AM   #6
musti72's Avatar
ok thanks
I need a clutch spring how to salteen Nitro Off-Road 3 11-10-2007 05:00 AM
Clutch Spring BREAKING!!!! Djballen Nitro Off-Road 2 09-30-2007 05:37 AM
CLUTCH SPRING TUNING tsanc10 Nitro Off-Road 1 09-16-2007 04:02 AM
Clutch spring setup Bulldawg RC Electric Off-Road 6 04-26-2007 10:48 AM
Clutch spring tool kahuna2793 Electric Off-Road 6 04-29-2006 07:12 PM
