Old 06-22-2003, 10:24 PM   #1
Talking Porting For Dummies 101
i want to start this thread mainly because i want to learn how to port my engine.i want to know how to port and what tools are needed.thanx
shortyboy is offline   Reply With Quote
Old 06-22-2003, 10:31 PM   #2
me43's Avatar
you mainly need metal grinding tools, but im not to sure which ones to use for polishing
me43 is offline   Reply With Quote
Old 06-23-2003, 01:18 AM   #3
torchedlh's Avatar
Send a message via AIM to torchedlh
i'm guessing a rotary tool like a dremel...
torchedlh is offline   Reply With Quote
Old 06-23-2003, 12:53 PM   #4
You need a range of hard and soft cotton (I think they are cotton) bits and I also use some of the rubber polishing bits. You will also need a cutting and polishing compound. I personally have about 30 different cutting and polishing bits that I use. All depends on what kind of cuts you want to make and how big you want them to be.
BallPy is offline   Reply With Quote
Old 06-24-2003, 02:12 PM   #5
Eric Perez has a decent article posted on porting, just the basics but well described. The article is on an Ofna .12 redhead, but the methods apply to all standard RC engines. I HIGHLY recommend practicing on a junk motor first!!
-John
http://www.geocities.com/ericperez_2...ngine_mods.htm
Luckyman4 is offline   Reply With Quote
Old 06-24-2003, 06:27 PM   #6
EdwardN's Avatar
Default Re: Porting For Dummies 101
First of all I will recomend to find out what is wrong with the ports on your engine and what you wanna do with it. Just to cut extra holes won't help you at all. You need to know what kind of modding are you about to attempt, what will be timing on induction , transfer and exhaust, how big you wanna ports to be, forms etc. After you make your plan what are you going to do, you will need protractor ( I guess it is right name for tool to messure degrees). You need to mesure your timings and make nessecary adjustment. I personaly don't like to use power tool for it, I preferd to use diamond needle files for ports on sleeve, on the cranck shaft there is no too much choices-dremel, with green color abrasive. To make adustment for ports on cranck case you need to use fine bores for dremel ( I use custom made out of dental rotory tool).
But again, before you decide to cut the corners you need to understand what are you going to improve. It is most important point in moding the engines.
EdwardN is offline   Reply With Quote
porting for a picco .28?? KEITH Nitro Off-Road 28 07-09-2008 10:52 AM
porting and modding a trx 3.3 more$thanbrains Monster Trucks 2 07-13-2007 12:48 AM
Porting Bluey68 Onroad Nitro Engine Zone 0 06-10-2006 06:19 PM
DIY engine porting? moot Nitro On-Road 2 03-29-2005 01:22 PM
Porting .12's...... MaverickRacing Nitro On-Road 11 01-27-2003 04:43 PM
