Old 01-20-2008, 03:27 PM   #1
TRYMY4.0's Avatar
Trader Rating: 10 (86%+)
Send a message via AIM to TRYMY4.0
Default HPI RS4 questions
Hey everyone. Not really NEW to the RC world but I dont know everything about it. Also, new to this site. Anyways....I just bought a used but BARELY used HPI RS4 and I finally got it started and it seemed like it was running rich since i would go through a tank in about 1-2min. But now, when I try to start it, its trying to move the entire car. Some of my friends said the clutch is melted or a spring broke and the clutch is fully engaged now? Would that be the reasons? Do I have to change the entire motor out?
Also, I was looking for an exhaust for this motor...but since it is quite old i didnt know what would fit on it. But if you guys say I need another motor, what should I go with that will bolt right in? (not looking to break my pockets).
-Ant.
I appreciate all the help.
POOWWWWWWAAAAAAAAA SLLLLIIIIIDDDDDEEEEE!!!!
TRYMY4.0 is offline   Reply With Quote
Old 01-20-2008, 05:00 PM   #2
PocketAce's Avatar
So, you're racing the stock engine, right? Is that a Nitro Star .15 FE or something else?
About that problem, I agree that it is the clutch. Just buy a new set of clutch shoes and springs from tower hobbies or your LHS.
About the engine, why don't you go for the HPI engine replacement plan and get yourself a .12 or .18?
One and only car: HPI RS4 2!!!
PocketAce is offline   Reply With Quote
Old 01-20-2008, 08:59 PM   #3
TRYMY4.0's Avatar
bc im a noob and just got this yesterday. lol. I will take it apart tomorrow and see what has happened on the inside. the car starts but takes off in an instant. so I assume it is stuck engaged.
Old 01-20-2008, 09:48 PM   #4
It could be the clutch engaging too early. try changing the clutch and clutch springs. leaving the springs installed for long periods can soften the springs due to the continuous tension.
If the clutch were stuck the engine should stall as soon as you let off the throttle. So aside from the clutch check your engine tune and the clutch bearings.
Genius is offline   Reply With Quote
Old 01-21-2008, 12:47 AM   #5
PocketAce's Avatar
That's what it sounds that happened. From the first post, it looks like the car moves forward and then stalls, what would translate in a bad clutch.
OP: The HPI engine replacement program lets you send them the old engine and get a brand new one for a special price. Read the following link for the engine exchange program which yields some very inexpensive good engines:
http://www.hpiracing.com/engineexchange/
Old 01-22-2008, 07:19 AM   #6
TRYMY4.0's Avatar
I appreciate it guys. But since im not a RC guru, i barely know what ya'll are talking about. lol.
I changed the clutch and I still had the saem result. It stayed engaged. I dunno, might have to take it to a pro but I really dont want to put a ton of moeny into it if it is so old and not worth it. Also, i cant get the motor out. Seems like he used loctite. I will try my best.
-Ant.
Old 01-22-2008, 01:20 PM   #7
PocketAce's Avatar
Turn on your radio and check your carb opening. At idle and braking it should be around 1.5mm.
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
B4: Kit vs RTR, Questions. BelialX13 Rookie Zone 15 02-14-2008 04:57 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
TNX QUESTIONS chrometwanks Monster Trucks 2 02-03-2006 06:02 PM
TB questions nekmiyevo2 Electric On-Road 7 08-11-2005 09:37 AM
