Engine question
Old 06-20-2003, 09:16 PM
Default Engine question
hey guys,
im about to race my nitro for the first time tomorrow, and i got my car together and everything works fine and all, the engine can idle forever but when i floor the throttle it dies, but when i gas it smoothly it can rev up. It is a nova cx-12, any ideas?
thanks
Johnny
Johnnytc3 is offline
Old 06-20-2003, 09:42 PM
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
sounds like your engine is a bit too rich, when it idles does it makes 4-stroke engine sound ?
Tag is offline
Old 06-20-2003, 09:45 PM
no it sounds ca paak ca pacck really fast like somthing is whipping. I think the idle sounds right bc it sounds just like other ppl's cars.
Old 06-20-2003, 09:55 PM
Tag
Tag's Avatar
here's the easiest way to check your car, start your engine and let it idle a few minute until the engine heat up, then pinch the fuel line, if the engine takes more then 6-8 seconds to die then you can lean your low end a bit, now take it to the track and set the high end, try to control engine temp around 230 +- range, until you are satisfied with your high end, open 1/12 turn then you are all set, of course there are other varibles that affect the engine such as %fuel you run, type of glow plug, track temp , pipe etc .
Tag is offline
Old 06-21-2003, 04:13 AM
RayJ's Avatar
Default Low End
The low end definately sounds to rich. I would lean the low end in one hour increments until the car takes off from a stand still w/o bogging down. You may have to do this several times. Each time just do a 1hour turn on the screw. If you look at the low end mixture screw and think of one full turn on the screw as 12 hours, then a one hour turn turn is just 1/12 of a full turn. You don't want the low end to lean either. So take your time.
RayJ is offline
Old 06-24-2003, 07:41 PM
TRF_TG10R's Avatar
i have the same problem....when i lean the hs needle it just dies ...
TRF_TG10R is offline
Old 06-24-2003, 08:01 PM
trf,
i put mine back to factory settings and now i can drive it, but when i idle for a long time (10+ secs) and gas it fast then it dies, but other than that it sorta works now. You should try putting it back to factory settings.
Johnny
