Old 06-19-2003, 03:56 PM   #1
Marines's Avatar
Send a message via AIM to Marines
Default RS4 SS isnt shifting
I rebuilt my 2-speed a few days ago and now my car isnt shifting at all...what could the problem be?
Marines is offline   Reply With Quote
Old 06-22-2003, 03:36 AM   #2
lee82gx's Avatar
i'm having the same problem...
i even tried different tensions on the shift point adjustment...
Question :
i believe the less i screw the ball in , the faster the shifting should be right?
but i tried almost all the way out but still it wont shift :cry
lee82gx is offline   Reply With Quote
Old 06-22-2003, 06:36 AM   #3
Marines's Avatar
It was shifting before i rebuilt the 2-speed, but it was shifting late. The 2-speed adjustment screw was a little off, so I wasnt able to adjust it from there. So I had to rebuild the whole 2-speed. And now it doesnt shift
Old 06-22-2003, 07:49 AM   #4
lee82gx's Avatar
i thought i knew why,but even after i rectified that , it still isnt shifting.
there are 2 screws,one for shifting point.on my car,the other screw was loose.
however,even after screwing it back in i still cant feel any shifting on my car.
Old 06-22-2003, 08:29 AM   #5
lee82gx's Avatar
by the way , are u using 86050a(silver spring) or 86050b(black) spring?
i assume u have the 12SS engine?
Old 06-25-2003, 09:17 AM   #6
Aggdaddy's Avatar
Hey, I was wondering about that too. I just built my SS not too long ago, and yesterday I was breaking in the engine, but I never could get it to shift. I made some changes, like adjusting the full throttle ( my throttle linkage was only giving me like 75% throttle ) and turning the two speed ball (black spring) 3 turns out and will try again tonight.
Has anyone noticed a drop in compression (pull starter rope, waay too easy to pull after initial break-in)?
Aggdaddy is offline   Reply With Quote
Old 06-25-2003, 09:35 AM   #7
lee82gx's Avatar
have u thread locked the 2nd gear to the main shaft?
that was the problem in mine.
or u can try lock in ,unlock 2 turns with the silver spring.
sometimes,the gear shifts too early before u can even notice.
hmm,if u consider the pull starter being too easy to pull as loss of compression,yes i do notice it.
Old 06-25-2003, 12:45 PM   #8
Aggdaddy's Avatar
Locked the 2nd gear to main shaft? Do you mean the small set screw that sits right next to the spring adjustment (to shift) set screw. I threadlocked it just like the manual said so. I don't remember any other way to "lock" the 2nd gear to the shaft.
Old 06-25-2003, 09:33 PM   #9
lee82gx's Avatar
yes,that's what i meant.otherwise see if u installed it the wrong way(back to front?)
Old 06-26-2003, 10:21 PM   #10
Aggdaddy's Avatar
Hey guys, if you haven't already noticed it, it is very easy to get the direction of the "finger clutch" confused. I had mine backwards. Facing the car forwards or point the front end away from you, if you look down into the hole where you adjust the two-speed screw, it should be to the right of the threadlocked "shaft" screw. Mine was to the left before I spent about two hours changing it around. (lost one of the parts :-( )
Another tip, something I just noticed, you guys might have already did it though. The brake screw that screws into the part that presses the brake pad, adjust it so that it sits flush with the brake pad. It brakes a heck of alot better than when you screw the brake screw all the way to the top.
WANTED: K&B 3.5-7.5CC outboard. yeah i know this isnt a boat site but.... Nitro_Racer_1 R/C Items: Wanted to Buy 0 01-24-2008 10:15 PM
The Mini T isnt dead! team3six Micro and Mini Scales 5 01-24-2008 10:17 AM
This isnt a forum for spammers wild gopher RC Flight 4 11-06-2006 12:10 AM
ahhhhhhh xbox live isnt working primusblowsgoat Chat Lounge 3 02-23-2005 07:59 AM
isnt the .................. HEWITT Electric On-Road 19 08-09-2004 08:43 AM
