Old 01-10-2008, 01:59 PM   #1
Default How do I make my own LED Light Kit?
What parts do I need and how do I make my own LED light kits? I believe normal size is 5mm? All info is appreciated and step by step intructions would be great!
ScruB.x3 is offline   Reply With Quote
Old 01-10-2008, 02:34 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
http://www.theledlight.com/ledcircuits.html
http://unclean.org/howto/led_circuit.html
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 01-10-2008, 03:27 PM   #3
I pretty much knew most of that, but I was wondering how to mount them in the body, parts I'd need for mounting, would I just buy a plug that would fit into my receiver for the wires, and how would I connect two LED's (a pair for the front, pair for the back, etc.) to one plug?
Old 01-11-2008, 11:01 PM   #4
Anyone?
Old 01-12-2008, 02:26 AM   #5
Roelof's Avatar
Go to a (online) electronics shop and you will find leds in all sizes, shapes and colours. With that you can find mounting equipment as well. Calculate the resistors and buy them
And what must we explaint with the wires and plugs ?
It is something you have to figure it out by yourself what is best for you.
This is what we call modelling !
Old 01-12-2008, 01:45 PM   #6
Sow&Steady's Avatar
Scrub, if you can read Chinese (or is this Japanese?) then go to this page. LED how-to galore!!!
The guy even LED'ed his Tx and there's a 3gp movie too.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 01-12-2008, 01:53 PM   #7
Roelof's Avatar
Nice, such a transmitter, have you seen my Micro pitboard ?
Old 01-12-2008, 06:14 PM   #8
meronr's Avatar
Roelof I love pit board it is totally awesome
Meron Rubinowitsch
meronr is offline   Reply With Quote
Old 01-12-2008, 06:21 PM   #9
That is very nice. and thanks for the help
Old 01-17-2008, 05:48 AM   #10
paul73rc's Avatar
Trader Rating: 5 (78%+)
Nice pitboard there, looks awesome. So do some of the other projects. Does anyone know what would happen if I overdo the leds with resistors? Coz I don't know how to work out the resistors ohms, watts all that science stuff. lol. Cheers, all help appreciated
paul73rc
paul73rc is offline   Reply With Quote
Old 01-17-2008, 07:29 AM   #11
Roelof's Avatar
Normal leds (yellow, green, orange and red) uses 2 volt @ 20mA
Blue and white leds uses 3.5 volt @ 20mA
(no high bright leds counted, those will consume 50mA or more)
The resistor has to take care of the rest of the voltage. As example a green led on 12 volt needs 2 volt for the led and so 10 volt for the resistor.
R=U/I so 10/0.02 is 500 ohms. 500 is not in the standard E12 list, the best choice is 470 or 560 ohms. Watage is UxI so 10x0.02 = 0.2 watt, normal resistors are .25 watt
With my pitboard I used 2 leds and one resistor in a row at each side.
2x blue leds makes approx 7 volt so the resistor takes 5 volt from 12v.
5/0.02=250ohm, it is not listed in the E12 list so I used 270 ohms.
You can not use more leds in in serial than the voltage supplied, be sure you have to get some voltage over the resistor.
You can use a current from 10mA up to 30mA so you have some play with the resistors, to high current will result in a short life and to low current will give less light.
Be sure the resistor has enough watage, if not it will burn or have a short life.
E12 list:
http://www.st-andrews.ac.uk/~jcgl/Sc...rt2/Page2.html
Old 01-17-2008, 07:36 AM   #12
Roelof's Avatar
E12 list:
ott-light Zac R R/C Items: Wanted to Buy 5 05-15-2008 02:10 AM
LED light kit? Ha! Havoxx Electric On-Road 1 06-25-2007 10:35 AM
XXX-S with light hop-ups thedudeaturdoor R/C Items: For Sale/Trade 6 05-31-2006 07:02 PM
pit light 17driver R/C Items: Wanted to Buy 8 03-16-2004 01:11 PM
Light up gearless Electric On-Road 3 12-01-2003 05:51 AM
