Old 06-17-2003, 06:14 AM   #1
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default Cleaning agent
Does anyone know why sort of cleaning agent can mix with the fuel, so it's stop carbon to build up on P/L ???
tl2111 is offline   Reply With Quote
Old 06-17-2003, 06:18 AM   #2
tl2111's Avatar
Default Re: Cleaning agent
Sorry typo error !!!
Does anyone know what sort of cleaning agent can mix with the fuel, so it's stop carbon to build up on P/L ???
Old 06-17-2003, 06:23 AM   #3
RClover's Avatar
'MOTOR UP' should be quite good!!
RClover is offline   Reply With Quote
Old 06-17-2003, 06:29 AM   #4
tl2111's Avatar
RCLover
What is MOTOR UP??? where can I get it and what is the mixing ratio. thanks
Old 06-17-2003, 06:34 AM   #5
RClover's Avatar
t,
that was a joke, dont take too seriously!
Motor Up is one additive agent to be added into old junk cars/ motors ...
Old 06-18-2003, 08:25 AM   #6
ive heard alcohol is a good cleaner and ive tried carburator cleaner as well.but there might be better stuff to use.hope this helps.
shortyboy is offline   Reply With Quote
Old 06-18-2003, 10:16 AM   #7
You could try Gumout engine varnish remover, it never works well on real cars but who knows.
AreCee is offline   Reply With Quote
Old 06-18-2003, 11:16 PM   #8
Impreza's Avatar
Send a message via ICQ to Impreza
I have used Mother's aluminum polish before, it does a fairly good job of cleaning everything up.
Impreza is offline   Reply With Quote
Old 06-18-2003, 11:44 PM   #9
Impreza is right about the Mother's aluminum polish works just awesome and use it myself.
A couple people in our club have been using Sidewinder fuel in the last couple months and finding out the carbon does not buildup even close to as much with Bluethunder. Not sure though what the difference in the two Nitro Fuels is.
corwin is offline   Reply With Quote
Old 06-19-2003, 05:17 AM   #10
sausage_link's Avatar
Send a message via ICQ to sausage_link
he wants to mix it with the fuel
not use it by itself
you could maybe mix one of these listed agents with some after run oil
sausage_link is offline   Reply With Quote
Old 06-19-2003, 05:53 AM   #11
it
it's Avatar
Send a message via AIM to it
[QUOTE]Originally posted by tl2111
Does anyone know why sort of cleaning agent can mix with the fuel, so it's stop carbon to build up on P/L ??? [/QUOTE
You cannot mix anything w/the fuel the mixture would not be the same.
However, I use something after running my cars on a race day.
I use Super X break cleaner. It comes in a spray aerosol like the Duratrax and Hpi cleaner. Its $2 in a automotive store. Make sure do not spray any electronics. This stuff is too strong to burn your battery pack. Just spray the motor, pipe, and the P/S.
Trust me, this thing works. we use this for rusted brake rotor. Imagine this thing can clean a 100,000 mile Brake rotor for a real car what more for just carbon in your Micromotori.
it is offline   Reply With Quote
Old 06-19-2003, 09:31 AM   #12
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
If you mix any solvent based cleaner (such as brake cleaner, alcohol, etc.) with your fuel, you will damage the fuel - there is oil in the fuel that the solvent additive will break down.
I wouldn't use a brake cleaner after my run, either, because I want as much oil to cover all the surfaces as is possible (within reason - I don't FLOOD the thing but I don't want to REMOVE oil either). The brake cleaner would break down and remove the oil that I want in there to protect against any corrosion.
Best bet - pull the piston and use some Mother's to clean it off. A little carbon on it isn't going to hurt much. If you keep it at a good operating temp you shouldn't build up too much and it isn't too difficult to pull the piston and clean it - it's not a bad idea to do this regularly anyway.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 06-19-2003, 12:06 PM   #13
it
it's Avatar
Default I
I have been using this and nothing happens in the performance of my motors.
I saw some good results. There were no black or burned carbon in the P.S.
After u spray just drop an after run oil then move the flywheel. At least its a fresh oil from the bottle not the burned oil from the fuel.
After combustion takes place, that oil and carbon are already mixed up.
I already said you cannot mix anything with nitro it will be not the same mixture.
Would you want a cleaner oil for storing without carbon?
Differnet opinoin, in different people. I understand that, I am not forcing everyone to do this. However, I am suggesting it.
Give it a try @ least once, then give me a feedback.
Old 06-19-2003, 12:19 PM   #14
Default HI IT
Where did you get that idea?
Where are you from?
I am using the same thing that I bought in Murray's, and PeP boys auto store.
I am pretty new in this forum, but I am in another forums.
I just read people's suggestions, tips, and tricks. I bought something here in this forum, but never had a chance to chat with the racers.
itoy is offline   Reply With Quote
Old 06-19-2003, 12:27 PM   #15
Default It
got PM
I AM CLEANING OUT EVERYTHING!!!! OneBadFirstGen R/C Items: For Sale/Trade 34 02-24-2011 09:16 PM
Cleaning up: Rev 5, mx3, rs4 3 yzf-r1 R/C Items: For Sale/Trade 0 02-12-2008 12:01 PM
Thunder tiger agent in JB mclan Malaysian R/C Racers 3 09-18-2004 04:07 AM
Agent for Buying & Selling Eric Cheng Singapore R/C Racers 0 10-29-2002 08:39 PM
