Old 01-03-2008, 11:50 AM   #1
Default Foams for unprepared road?
I am getting tired of my tires getting ripped away from the rim, is their a company that makes foam wheels that are good on unprepared unblown roads or asphalt?
http://www.myspace.com/sarsinajar
http://www.impactpaintball.com
Avid Paintballer and Technician
Traxxas 4-tec 3.3 RWD only
Rustler VXL RPM all around geared 32/76
MaxAmps 11.1 8k LiPo
aznrevlazn is offline   Reply With Quote
Old 01-03-2008, 01:24 PM   #2
dnitro's Avatar
When bashing on unpreped surfaces, you have no choice but to use the softest foam <35 shore (if that is all you got). The softer foams will chunk easier than harder ones. Use superglue on the sides of a new set of foam to minimize chunking. Add more camber all around (I'm not sure if you can add camber on your Traxxas 3.3). Otherwise, you may have to try out rubber tires.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 01-03-2008, 02:18 PM   #3
GHETTOTEACHER's Avatar
Jaco, GRP were a few brands that I used on parkinglot tracks. 35-37 shore tires, 35wt oil and med to soft shock springs. Remove rear swaybar. Glue the outside tire/rim so you won't chunk. Cut tires to F/R 60/61. That should give you some grip.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 01-03-2008, 03:30 PM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
I would switch to rubber tires. You never going to get a soft foam tire to last on ANY un-prepped surface. Foam tires give the best grip, But have the shortest life span.hopes this helps
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 01-03-2008, 03:43 PM   #5
impalabob64's Avatar
Send a message via AIM to impalabob64
Default hey
Here in Florida ,we run 42 shore frt,an rear, if you hve a tire truer, you can round the egdes, an superglue the edges, this will prevent you from chunking your tires.Hope this helps.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 01-03-2008, 07:52 PM   #6
ty for the reply everyone!
Need LOTS of 1/8 off road tires and foams!! new to rc cars R/C Items: Wanted to Buy 2 05-10-2008 09:33 PM
1/10 Scale On-Road Foams bvoltz R/C Items: For Sale/Trade 3 12-09-2007 09:25 PM
1/8th Truggy On-Road Foams/Treadeds ScudMan Nitro Off-Road 0 11-12-2007 08:55 AM
New 1/8th on-road foams Roger R/C Items: For Sale/Trade 6 10-20-2005 01:39 PM
GT1 1/8th On Road Foams ATOMIC Nitro On-Road 2 06-20-2005 12:08 AM
