Old 06-12-2003, 06:49 PM   #1
Default is there any way that i can bend a bent manifold back to its original position?
as above..
i had a little knock at the exhaust area and my exhaust hook came loose..
so as my exhaust is loosly hanging, i realize that my manifold is not in its original shape anymore..
so is there anyway i can bend it back?
i am still new to this hobby, so i would need some advice
thanks!
vSgen is offline   Reply With Quote
Old 06-12-2003, 09:07 PM   #2
vones's Avatar
Default Re: is there any way that i can bend a bent manifold back to its original position?
Originally posted by vSgen
as above..
thanks!
Qutie difficult.....I tried once n there only an extend as to how much to bend back to 'original shape ' .If it's near the manifold opening then u can try to use a round spocket n force it in....the ones that comes in a T shape to unscrew the plugs ,wheels nuts etc...trial n error
vones is offline   Reply With Quote
Old 06-12-2003, 10:31 PM   #3
popsracer's Avatar
Default Manifold "Shaping"
If not Kinked, use a Cigarette Lighter set on High Flame to heat the metal where you want it to bend.
Use something that fits inside the end of the Header (Pipe end)and Bend GENTLY while heating. It should go back pretty close to it's original position.
popsracer is offline   Reply With Quote
Old 06-12-2003, 11:09 PM   #4
vones's Avatar
Default Re: Manifold "Shaping"
Hmm...good idea there....
G4S Chassis bend uniquexme Nitro On-Road 19 12-06-2006 03:10 PM
what can bend a slipper shaft? builthatch Electric Off-Road 2 11-11-2006 12:26 AM
Need help to set midrange needle back to original setting. dameetz Nitro On-Road 2 06-29-2003 06:31 PM
Trade: New NTC3 Side Exhaust & Manifold for your Brand New Rear Exhaust & Manifold fish66 R/C Items: For Sale/Trade 1 07-30-2002 04:54 PM
