Old 12-19-2007, 10:52 PM   #1
terex839's Avatar
Unhappy require OS GS15R tunning tips
hi guys,
im new to this forum hopefully u guys can help me out with some tunning tips for my OS GS15R engine.Im having problems starting it at the moment.tried several attempts but it still wont crank up........hmmmmm wonder why?
terex839 is offline   Reply With Quote
Old 12-20-2007, 12:15 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
Check the glowplug and its glowbattery
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 12-20-2007, 06:14 AM   #3
terex839's Avatar
Unhappy
Originally Posted by terex839 View Post
hi guys,
I've checked the GP & GPB its ok.i tried starting it up late this afternoon but still failed.
Old 12-20-2007, 06:53 AM   #4
Roelof's Avatar
Adjust the throttle trim to a quart throttle, hold a finger on the tailpipe of the exhaust, give some pulls on the pullstarter, place the glowbattery en start it up.
What fuel are you using ?
Old 12-20-2007, 11:42 PM   #5
terex839's Avatar
im using tornado fuel 25%
Old 12-21-2007, 03:37 AM   #6
ViperSkull's Avatar
wtf way to much nitro man, run 16% max
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
Old 12-22-2007, 08:25 AM   #7
terex839's Avatar
i dont think we have the 16% fuel sold here but i check tomorrow.
Old 12-22-2007, 09:07 AM   #8
Roelof's Avatar
Should not be the problem for not starting up the engine.
More tricks:
- try it without airfilter
- drop some fuel directly in the air intake and try it then.
Is it a new car ?
Did you do anything to the car (take it apart) ?
Is the pressure fuelline connected (from exhaust to tank) ?
Old 12-22-2007, 05:59 PM   #9
terex839's Avatar
its not a new car its been with me for 1 1/2 yrs now but seldom plays it cause i,ve got another car V1 RRR which runs pretty well. i manage to start it up run it about 10 min. stopped it after that & try to start it up again.........fail to start.
now the problem is when the engine is hot or warm its hard to get it started.
i wonder if the glow plug needed to be change.....
Old 12-22-2007, 06:03 PM   #10
terex839's Avatar
i did take it apart but not totally apart.just to install some optional parts ...graphite top deck, two speed transmission.mostly on the bodyworks not the engine ..
Old 12-23-2007, 03:47 AM   #11
Roelof's Avatar
You are sure you did connect the fuelline correctly, not to the pressure nipple on the tank ?
Old 12-23-2007, 08:12 AM   #12
bozla's Avatar
I've got the same engine and it runs just like that too. I think maybe it's time for a new piston and sleeve my friend. Or just send it to rayaracing.
bozla is offline   Reply With Quote
Old 12-23-2007, 08:40 AM   #13
terex839's Avatar
Thumbs up
im positively sure & by the way i finally manage to run it.rectify the problem coming from the clutch bell.the rubber inside seems rubbing against the bell to hard due to to much loctite applied to the locking screw.
but any way thanks for the tips and advice.appreciate it very much.
now its time for me to do some trisl n error on the two speed transmission which i newly installed.how much would it cost for a new transmission kit at ur place.
adding 40 series wheels, does this require any changes? atebit Rookie Zone 1 04-02-2008 11:40 AM
URGENTLY REQUIRE MM MOTOR COOLER Green Machine Australia Wanted to Buy 9 11-09-2006 01:54 PM
Some Sports Only Require One Ball..... MaverickRacing Chat Lounge 9 03-14-2002 10:11 AM
do collari engines require their own manifold? contact Nitro On-Road 3 02-25-2002 09:03 PM
