Old 12-17-2007, 02:29 PM   #1
Send a message via AIM to FITO
Default break-in bench technics
i just got a hudy break-in bench and i would like to know what are some of technics some of you guys are using to properly break-in a engine in a bench thanks
RODOLFO
KYOSHO M3, PICCO, KO PROPO, MAXY FUEL
FITO is offline   Reply With Quote
Old 12-17-2007, 02:49 PM   #2
captian's Avatar
most important take you time heat cycle and 4 stroke
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 12-17-2007, 09:14 PM   #3
pepsidawg's Avatar
KEEP OR PUT HEAT IN THE MOTOR! This cannot be expressed enough! Wrap the motor with foil. Block air from prop from getting to motor. Preheat motor with heat gun(it is your friend) to at least 200 F., 230 or 240 is better. With rich breakin settings you will have to hold the heat gun on head to maintain the temp. Use a temp gun. Just don't let it get too cool when its running. The motor gets to much abuse when its in the car and there is no sence in abusing it on the bench, just keep that thing hot and rich on the bench. When you put it in the car you might still need foil on head to maintain temp, just don't run it cold(below 200 F.) Maintaining temp in the car will be easier because you will start to lean it and that helps build temp.
Kevin Olson
pepsidawg is offline   Reply With Quote
Old 12-18-2007, 07:46 PM   #4
new3's Avatar
just remeber one thing when you break in a motor they are all different and each motor requires a different breakin techneque
www.new3racing.com, OFNA, Mugan MRX5wc, www.speedshophobbies.com, western engineering, redline racing fuels,
new3 is offline   Reply With Quote
Old 12-18-2007, 10:46 PM   #5
casimirsa's Avatar
I have use a few makes and models of .12 and .21 over the the years and have used the method that pepsidawg describes in his post.
I would like to add that it is necessary to also block airflow over the crankcase. Doing that makes life much easier to control the temperatures!
Secondly only heat up the motor on the cooling ahead allowing time for the heat to be drawn into the p/s and crank case.
The reason for this is that if you heat the motor from the sides you never will get an even expansion of the p/s causing uneven wear.
"Horsepower is how fast you hit the wall. Torque is how far the wall moves after you hit it."
TM G4S (ED), TM G4S,SERPENT M2+835+960FD, MUGEN SEIKI MRX4-X, MUGEN SEIKI MRX4 (WORLDS CHASSIS), MUGEN SEIKI MTX4, MUGEN SEIKI MBX5T, HPI PRO4, TAMIYA, PALMARIS, RB C5+C5 RODY+V12 RODY, NOVAROSSI, JP, AXE ROSSI, MEGA, NOVAMEGA KHM, KO PROPO, HITEC, GRP, UFRA, ROBITRONICS, SJ, LRP
casimirsa is offline   Reply With Quote
Old 12-20-2007, 09:00 PM   #6
YLLIB's Avatar
I break the motor at an idle for one tank @ 180-200 Deg. piston BDC and let cool for 10 min. Then I do two straight tanks at an idle 190-200 Deg, and let cool for 15 min, piston BDC. Then two more straight tanks @ 200-220 Deg, and let cool for 15 min then on the track for a tank around at 200-220 for a tank and then let her rip. Also when breaking in the engine I do clear it out a couple times a tank at 4 stroke level, just to clear it. I also made a sleeve that wraps around the head during break in for even temp, it is made from race car exhaust insulating wrap, it made to wrap headers, and it works awesome and very temperature control around the engine body nicely.
www.speedworldraceway.com
YLLIB is offline   Reply With Quote
BREAK IN BENCH COOLEY R/C Items: Wanted to Buy 3 03-28-2008 01:13 PM
break-in bench technics FITO Nitro Off-Road 2 12-18-2007 12:10 AM
hudy break-in bench lil-bump Nitro On-Road 3 08-25-2007 08:24 PM
Serpent Break in Bench RCNUT R/C Items: Wanted to Buy 0 02-26-2005 06:07 AM
Bench break in --- how is it done? stefan Nitro On-Road 2 11-05-2003 04:43 AM
