Old 07-16-2003, 06:55 AM   #226
alucard13's Avatar
Originally posted by Isaac
I like this aluminum because it stays clean. At least so far. Handling is better and I got my motor to mesh correctly (MT12). Took some time but I got it. After racing with it the effort was worth it. People just look at it and say... who makes that? I laugh. When you pick up the stock chassis compared with this one it's a joke. Thank you protc3 but I still want the other mounts.
Try to do the mesh without the transmision brace on the engine side. I got the low center mounts, but it still didnt mesh correctly. What i had to do was take off the transmission brace on the engine side. I have an MR12.
alucard13 is offline   Reply With Quote
Old 07-16-2003, 09:42 AM   #227
I already got it to mesh. Mine is fine.
Isaac is offline   Reply With Quote
Old 07-16-2003, 10:15 AM   #228
alucard13's Avatar
I couldn't get mine to mesh until i took out the transmission brace. I may have a warped transmission case. Everything else seems fine. Glad to see you got yours to mesh right.
Old 07-16-2003, 05:39 PM   #229
alucard13's Avatar
Default 5 cell flat pack
I cant seem to get my battery in between the holders. I have both holders facing each other so that the cut out part goes on the battery. I have a futaba nrf5600. it seems to big.
nevermind. Its a little wierd on how to get it in. I put the other silver thing on the battery and then lowered the battery down and screwed in the silver thing. its ok now
Old 07-16-2003, 06:02 PM   #230
alucard13's Avatar
I am running out of room in my receiver box. The wire for the bat pack and the wire that the batt pack hook up to are quite long. I was able to put it in nice and snug along side the battery pack and chassis. would this hurt it? what if i put a msall piece of duct tape to secure and protect it?
Old 07-16-2003, 06:05 PM   #231
alucard13's Avatar
Originally posted by bbntc3
last one
what did you use to mount your antenna? and what kind of hole did you have to drill on the receiver case?
Old 07-16-2003, 08:39 PM   #232
Registered User
Send a message via AIM to bbntc3
It's just a GS (General Silicones) ant. mount. Drill or ream a hole in the reciever box and bolt it in. File a notch in the back of the lid for the ant. to go through.
Are you guys sure the left rear chassis brace is'nt rubbing the pinion gear causing you to have no mesh? The gear don't really clear the brace without the BMI mounts. Well at least mine did'nt. And I tried 4 diff sets mounts, (Golden Horizon, AE(stock and Team mounts), K-Factory. You say you have mesh with out the brace? right? Theres no way you could bolt the braces on the car and loose gear mesh. The way the diff bolts and the chassis is made theres no flex there .
bbntc3 is offline   Reply With Quote
Old 07-16-2003, 09:54 PM   #233
alucard13's Avatar
If i put the brace on, the pinion gears scrap the bottom of the brace. But when its off, everything works fine.
Old 07-16-2003, 11:44 PM   #234
rrgt_kid's Avatar
Originally posted by Jim Reeves
You can use any 5 cell flat RX pack. I'd recommend blue thread lock on all metal to metal screw connections.
hi jim the chassis look really kool, im interested and can you please tell me the weight the strength and how much to ship one to Brisbane Australia.
jeremy.
rrgt_kid is offline   Reply With Quote
Old 07-17-2003, 04:17 AM   #235
Thanks guys it went together a treat.
First test flight sunday.....
xray vision is offline   Reply With Quote
Old 07-17-2003, 05:50 AM   #236
bbntc3- shims under the brace. Ran my chassis last weekend and will again this weekend. Yes it is better than stock. Maybe a little hand fitting but it's worth it.
Old 07-17-2003, 06:53 AM   #237
alucard13's Avatar
What kind of shims and how big?
Old 07-17-2003, 09:17 AM   #238
I'll take pictures later when I get home from work.
wilsonproperties1.com
Old 07-17-2003, 09:52 AM   #239
Default rear brace
Re: the pinion gear hitting the bmi rear brace
just dremmel the rear brace till it clears the 1st gear pinion.
another thing i notice is that there’s a 2mm gap from the front of the chassis to the front bumper brace?? part no#2226
saka is offline   Reply With Quote
Old 07-17-2003, 10:41 AM   #240
Saka... I was going to do that but the chassis was just too pretty.
I noticed the gap too. Still ran it. Night and day at least for me from the stock piece.
Nitro Tc3 Chassis sean R/C Items: Wanted to Buy 2 08-08-2004 05:12 PM
RTR Kyosho USA-1 Nitro Crusher trade for HPI Nitro mt or mt2 rolling chassis RCNitroDude999 R/C Items: For Sale/Trade 2 05-13-2004 04:55 PM
WTB: Nitro TC3 Stock Chassis rod_b R/C Items: Wanted to Buy 2 10-21-2003 08:11 PM
HPI NITRO RS4 (rolling chassis) mistercrash R/C Items: For Sale/Trade 2 06-15-2003 04:46 PM
WTB Nitro sedan chassis coastaltony R/C Items: Wanted to Buy 0 01-14-2002 01:21 PM
