Old 07-06-2003, 06:31 PM   #166
protc3's Avatar
the wheel nuts for the tc3 look like an 8-32 thread.an 8-32 srew is about .165 in diameter,a 10-32 is about .192 in diameter.hope that helps you guys.
jay
protc3 is offline   Reply With Quote
Old 07-06-2003, 07:05 PM   #167
Thankyou Uncle Jim
Have a guess what turned up at the local post office today?
SWEEET............
xray vision is offline   Reply With Quote
Old 07-06-2003, 07:34 PM   #168
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by hooked_on
I do and the manual and assosicated's website says 8-32 as well, but i emailed stormerhobbies and was told 10-32, so i am confused now.
its listed in the manual.....Part # and size..
here it is
http://www2.towerhobbies.com/cgi-bin...?&I=LXSG69&P=7
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-06-2003, 08:15 PM   #169
Registered User
Send a message via AIM to bbntc3
bbntc3 is offline   Reply With Quote
Old 07-06-2003, 08:26 PM   #170
Registered User
Car worked very good this weekend! Driving skills still lacks, but getting much better. We had to race the Bmain this weekend, but won it and bumped to the last starting spot in the A main. Car was on a rail and moving forward when driver error got on top a roadrail,(roadrail track systems) sent the car side ways back onto the track, got T-boned by another car, sent the metal radio tray into the driveshaft. This slows the NTC3 very much!
Old 07-06-2003, 09:05 PM   #171
Registered User
Here's a chassis setup we've been using and seems to work pretty good for us.
Track is new semi smooth pavement with a few small bumps, sealed and no traction compound on track or foams. This is a short track with some tight cornering and 100 ft back stretch.
14 to 16 second lap times.
Front
60 wt. oil
#3 pistons
Copper springs
front adjustable sway set at 45 degrees
12 degrees castor (more on power steering) both clips backside of a-arm
-2 camber
camber links inside hole
0-toe in
-4 droop
CRC Track magnets #2119 (db purple) trued to 63mm
balldiff 1/4 turn out
ride height 5mm
Rear
35 to 40Wt oil
#3 pistons
Copper springs
Camber -2
2.5 toe in
-4 droop
.078 swaybar
upper camber links inside hole
CRC Track Magnets #2120 (purple) trued to 62mm
ride height 5mm
This may help some people starting with the chassis if not good for others change spring rates first before trying something else. This setup with same spring rate front and rear, gives the car the same feel front and rear.
Old 07-06-2003, 09:11 PM   #172
fastharry™'s Avatar
did anything bend?.....what part of the tray got into the driveshaft?...teh reciever box?....
Old 07-06-2003, 09:42 PM   #173
protc3's Avatar
bb,let me know what happened to the receiver box and driveshaft.email me your adress and ill get you out a new box.
by the way, im running a very similar setup.i managed to beat my fastest lap time.went from 14.5 to a 14.3.i was the only one who ran in the 14's yesterday.and also set the new track record.i tq'ed ran first place the first 6 minutes until i went into pit and fouled a glow plug .it was only a 10 min main so i just called it quits.car was unreal.i managed to stay off the pipes all night.
i was overall a very happy camper.i felt so comfortable with it.
my set up was for a low traction minor bump track:
38 tires all around(yokomo)
red springs rear
copper front
#3 front pistons
#2 rears
40 wt shock oil all around
front and rear sway bars(not blade)
9deg. castor
2 deg. toe(rear)
2 deg. camber (rear and front)
0 deg toe (front)
1/8 turn out on front diff
1/4 turn out on rear
car was very stable,next to no roll,and didnt have to brake in the corner very much.only when i was trying to pass.i was able to carry massive speed through the corners.if it wasnt for that damn glow plug.lol
jay
Old 07-06-2003, 09:45 PM   #174
Registered User
If you look at the chassis theres a metal receiver box that the plastic Ae receiver tray sits in. Yes, it bent the metal box into the shaft. Maybe spot weld the box in the seams Jason. If I can get it bent back out straight that's what I'm gonna try. It will help. The odds of bending it in a wreck is there but not really good odds.. Just my luck is all! Not too knock the chassis, it's a sweet deal man! but the tray is the only weak link, and if theres a weal link anywhere, it always seems to haunt me!
Old 07-09-2003, 06:06 PM   #175
What throttle servos are you all using with the chassis?
Isaac is offline   Reply With Quote
Old 07-09-2003, 07:09 PM   #176
protc3's Avatar
the servo is spaced up just like the stock chassis with stock servo spacers.i use a futaba 3003 servo
Old 07-09-2003, 07:49 PM   #177
Oh duh... I just tried to put the servo straight on the chassis.
Old 07-09-2003, 07:56 PM   #178
protc3's Avatar
lol,what kinda track are you running on,high traction?
Old 07-09-2003, 08:05 PM   #179
Running on a parking lot. Traction is decent and can be hard on foams. I'm going to leave the set up I have on the car and recheck droop, camber and the like.
Old 07-09-2003, 08:58 PM   #180
alucard13's Avatar
the screws that come with the chassis, what screws do they replace?
also in the package there are 2 silver pieces with screws on the side. what is that for?
and what is the one big silver screw for?
alucard13 is offline   Reply With Quote
Nitro Tc3 Chassis sean R/C Items: Wanted to Buy 2 08-08-2004 05:12 PM
RTR Kyosho USA-1 Nitro Crusher trade for HPI Nitro mt or mt2 rolling chassis RCNitroDude999 R/C Items: For Sale/Trade 2 05-13-2004 04:55 PM
WTB: Nitro TC3 Stock Chassis rod_b R/C Items: Wanted to Buy 2 10-21-2003 08:11 PM
HPI NITRO RS4 (rolling chassis) mistercrash R/C Items: For Sale/Trade 2 06-15-2003 04:46 PM
WTB Nitro sedan chassis coastaltony R/C Items: Wanted to Buy 0 01-14-2002 01:21 PM
