Old 12-15-2001, 06:02 PM   #1
Default Lsd Diff
I DON'T SEE A HUGE DIFFERENCE IN INTERNAL PARTS BETWEEN A LSD DIFF AND A STANDARD GEAR DIFF. HOW DOES A LSD DIFF AFFECT THE HANDLING?
LURCH is offline   Reply With Quote
Old 12-15-2001, 11:01 PM   #2
Ah10's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Default Re: Lsd Diff
I am not sure if you are referring to Negative Diff that made by Kawahara or Kyosho.
Anyway, Negative diff VS standart gear diff:
Standard Gear Diff only have gears inside the diff obviously! and you will need to fill it with different weight of diff oil to make the gear diff loose or tight depending on what weight of oil you put in there!
Negative Diff, actually it has 2 different housing and sealed from each other and they are side by side. The only thing that go between both housing is the left outter drive. The housing on the right has regular gears that you put into regular gear diff and you will also need to fill it with diff oil,(different weight of oil will result loose diff or tight diff) and on the left side of the gear diff housing which is another housing that has 2 fingers clutch in there.
The concept is when the whole rear diff that pulls by the belt spins fast enough then the clutch will engage by concentric force then it will become a solid axle but when you slow down the concentric force is not enough to spin the finger type clutch fast enough so it will disengage then you will have diff action.
So the best effect or result from a Negative Diff is to use light weight of diff oil or diff lube to allow really smooth diff action for tight corners and when you punch out of the corners then it becomes solid axle and the car will rocket out the corners also the car will be much stable on highspeed straight away!
Hope that will help!
Ah10 is offline   Reply With Quote
Old 12-16-2001, 08:11 PM   #3
Default diff
THANKS FOR THE REPLY BUT WHAT I WAS TALKING ABOUT WAS THE KYO # VZW009 LSD DIFF (TOWER CALLS IT A TCD GEAR SET # LXAVW8 FOR $81.99)
Old 12-17-2001, 03:13 AM   #4
Lurch,
R-U in NY?
vapourtrail is offline   Reply With Quote
Old 12-17-2001, 11:53 PM   #5
Mauler's Avatar
Send a message via ICQ to Mauler
Default Re: diff
LSD works on the basis of friction acting on the floating blocks and the bevels... the TCD liquid is a lub and a coolant... when there is too much friction on the blocks, the gears and the blocks expands and thus locks up the whole system... with the presence of the fluid, the system unlocks itself rapidly... when there is a difference in torque transmission, the sytem locks up again...
One difference between the LSD and the negative diff is that the LSD does not lock up at a specific RPM, but the negative diff does... Depending on how you want your car to perform, the 2 diffs serves very different purposes...
Mauler is offline   Reply With Quote
Old 08-28-2007, 02:05 PM   #6
bugnet's Avatar
getting on an old topic to not open a new one,
is usefull an LSD diff on a FW-05T ?
guessing because of engine ´low´ power
thanks
bugnet is offline   Reply With Quote
Old 09-10-2007, 09:30 PM   #7
i'm reading about the negative differential i think it will be good to my car, but i'm looking all over online but i can't find anywhere to buy. Can anybody tell me where to buy it..... thanks
inutel is offline   Reply With Quote
Old 09-28-2007, 08:01 AM   #8
bugnet's Avatar
well, it works fine on FW-05T, not too much improvement, hugely recommend use of diff metal gearbox (3Racing on FW, Kyosho VZW020 on V1RRR)
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 08:49 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 10:18 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
front lock diff vs gear diff rhed Nitro On-Road 4 11-29-2005 02:20 PM
XRAY T1FK04, XRC 4.0mm Chassis, One-Way, Diff, Hudy Spring Steel Diff, and MORE! BobbyDoyle R/C Items: For Sale/Trade 10 08-18-2005 04:38 PM
