calling all old school guys........... >
Old 12-05-2007, 08:01 PM
Taylorm's Avatar
Default calling all old school guys...........
Guys, now i want to remove my flywheel from my old Novarossi but there is no room to get a socket/nut driver down into the recess to loosen the clutch nut. Any ideas?.....it's the clutch from an old BMT...... man how things change...it's a 4 shoe clutch and it's a leading edge setup??/
Taylorm is offline
Old 12-05-2007, 08:09 PM
occ
Trader Rating: 16 (100%+)
Yes, I used this clutch many years ago when I had my BMT.
I had to grind down the outside edge (like a chamfer) & make the bottom of the socket perfectly flat. I did this with a grinder in order to fit it in between.
I hope that made sense.
occ is offline
Old 12-05-2007, 09:17 PM
Taylorm's Avatar
.........so thin out the wall thickness and grind flat.........got it. thanks, Matt..........
Taylorm is offline
Old 12-09-2007, 07:23 PM
srsracer's Avatar
Post
you need a deep reaching 10mm socket
srsracer is offline
Old 12-09-2007, 09:55 PM
Serpentd's Avatar
I'm not 100% sure, but when I use to wrench on planes and stuff, I always needed a "thin walled" deep socket for things like this. I think I have a special one made by Craftsman or Snap-On. Try Craftsman first, you'll probably still need to grind it down, but not nearly as much. Do a search for the "Thin Walled" 10 mm deep socket. Regular everyday sockets are WAY thicker. Good luck man. Later.
Serpentd is offline
Old 12-10-2007, 05:46 PM
technazi's Avatar
For some reason I think I remember using a deep socket like that one needed for when I used to race the Ofna Colt. Yeah... I know....
Now where did I put that thing......???
technazi is offline
