Old 06-06-2003, 12:01 PM   #1
Default mtx3 setup help
hey guys, i'm new to this site, so thanks in advance for all of your help. i just got the mtx3 and i have been trying to set it up. out of the box it would seem great for a high speed track, but i'm in san diego and all we have here are parking lot races that are tight and technical. i've already installed a diff as opposed to the one way, and that made it easier to drive. now my problem is when i turn left, the car pushes and when i turn right, the car will spin out and do donuts. i've just been dialing out the servo to not throw to the right as much, but my steering off power suffers. i have a 5 port RB X12 and when i try to ease out of corners, the centax clutch engages so hard it causes the rear end to give. but anyways, i had the car on a hudy board and everything looks even, but there is something wrong. any suggestions would be great. front: -2 camber, in 1 toe. rear -3 camber, 2 in toe. thanks everyone.
mixinpixels is offline   Reply With Quote
Old 06-06-2003, 01:13 PM   #2
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: mtx3 setup help
Should the front be set as Toe out, instead?
eddiethefish is offline   Reply With Quote
Old 06-06-2003, 02:17 PM   #3
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I wouldnt suggest taking steering away from only one side. You might need to re-center your servo, then make sure you have the same ammount of steering throw on each side. Also make sure that both steering rods are the same lenght on each side.
Next, You might want to adjust your centax a little but for a more smoother throttle engagement, so that it doesnt jump as hard off the corner. If you loosen the centax a little bit, it will engage a little earlier, therfore you have a little more finger control, instead of a quick jump.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
MTX3 & V-0ne-RRR setup for Little Hampton Collins Australian Racing 1 06-26-2007 08:09 AM
Setup tips for MTX3 NITROTJ Nitro On-Road 3 01-10-2007 05:26 PM
Trade for Tamiya TXT-1? (MTX3, Setup Sys, etc.) performula R/C Items: For Sale/Trade 4 11-21-2005 10:14 PM
Mugenseiki Setup - Mtx3 Bengkel_Spanar Malaysian R/C Racers 15 11-01-2004 11:54 PM
Mugen Mtx3: Nitro Setup justinalamode R/C Items: Wanted to Buy 1 04-15-2004 05:42 PM
