Old 06-05-2003, 09:32 PM   #1
alucard13's Avatar
Default 5 Cell Hump or 5 cell flat?
i'm trying to find out what is better for my ntc3 reciever. A 5 cell hump or flat 5 cell? Also, where can i find on with the most power and what kind of charger should i get? I am going to be running a 2 hour endurance race and i need LOTS of battery power with a fast charger. what do you suggest?
alucard13 is offline   Reply With Quote
Old 06-05-2003, 09:35 PM   #2
me43's Avatar
get a flat one because it has a lower CG
and if you need ur batteries to last long
i would charge it at the slowest rate possible
me43 is offline   Reply With Quote
Old 06-05-2003, 09:40 PM   #3
alucard13's Avatar
then what is the longest lasting flat 5 cell i can get and how long will it last?
Old 06-05-2003, 09:46 PM   #4
me43's Avatar
if you can afford it/make it
i would make my own
if it could fit
i would use 5 2000 mah NMHI AA batteries
Old 06-05-2003, 09:49 PM   #5
alucard13's Avatar
where can i get the batteries, how do i solder them (ie what materials do i need) and what charger should i get?
Old 06-05-2003, 09:51 PM   #6
me43's Avatar
maybe something like this
http://www2.towerhobbies.com/cgi-bin...?&I=LXLX55&P=7
you can solder them with a sodlering iron
then you need to buy the plugs and heat shink
and maybe a super brain charger
Old 06-05-2003, 09:57 PM   #7
me43's Avatar
or i belive trinity came out with 2000 mah AA NI-MH batteries
Old 06-05-2003, 10:02 PM   #8
alucard13's Avatar
plugs and a heat sink? Wow, i dont know if i have enough room on the chassis for that.
Old 06-05-2003, 10:10 PM   #9
me43's Avatar
no not heat "sink"
heat sHrink
Old 06-06-2003, 07:44 AM   #10
alucard13's Avatar
DOH! I use the cell phone too much.
Old 06-06-2003, 08:45 AM   #11
Here's an idea for the enduro race.
Set up two AAA packs or AA packs with connectors. Or use two flat 5 cell receiver NiMH packs of 1000mah or >.
Install them both in the car, one under the radio plate and the other on top of the plate. You can use the same wire tie.
Attach the female connector of an aileron servo extension into the receiver and run the male end out to the batteries. So you can switch battery leads without removing anything.
Now all you need to do to switch batteries is to unplug the spent one and plug in the fresh back up and you're out of the pits in about 10 seconds or less.
AreCee is offline   Reply With Quote
Old 06-06-2003, 02:17 PM   #12
alucard13's Avatar
hey, thats sounds like a good idea. any particular flat 5 cell with charger you suggest?
Old 06-06-2003, 02:40 PM   #13
Yeah, didn't I mention any NiMH with 1000mah or more?
Use a trickle charger if you don't have access to a peak charger but it will seem like it'll take forever to charge two packs. About 20 to 30 hours per pack.
If you can use a peak charger that handles Rx packs and NiMH then you can charge a pack in about two hours at .5amp.
If you don't have access to either then buy two 4 cell AA holders with connectors to fit the servo extension and just swap them as I described. They may only last for a half hour per set but it's a lot cheaper than buying two Rx packs and a decent charger.
Old 06-06-2003, 04:00 PM   #14
alucard13's Avatar
Sorry about that. i didnt know if you liked any particular product line or not.
7-Cell Hump Pack - For Sale!!! Quaddude660 R/C Items: For Sale/Trade 7 04-24-2008 01:53 PM
new venom 5 cell hump pack 1200 mah extreme-rc Australia For Sale/Trade 3 01-12-2008 12:39 AM
For sale: Brand new OFNA 5 cell hump pack 1400 MAH JSY R/C Items: For Sale/Trade 1 04-12-2006 12:35 AM
Peak Racing 5 Cell Hump pack RacingShack R/C Items: For Sale/Trade 0 01-02-2006 11:44 PM
DYANMITE 5 CELL 1000mAh NiMh hump pack f/s! pics! CXDXH R/C Items: For Sale/Trade 0 02-18-2003 05:29 AM
