Old 06-05-2003, 08:55 PM   #1
Default Urgent Help With Centering of Steering MTX-3
I just bought a new KO 2143 Servo, to hopefully fix my problem if it not centering when I turn left and right. However after installing the servo I have tried to turn left and right, however the car still will not center probably, when turning right.
Anyway else have a suggestion or encounter this problem?
I do notice that if I turn right the servo makes a funny screeching sound.
Can you have a look at the attached photos and maybe work it out for me, its driving me insance.(sorry about the poor quality photos)
Let me know if need more information
Sami
ttektek is offline   Reply With Quote
Old 06-05-2003, 08:55 PM   #2
Left turn
Old 06-05-2003, 08:56 PM   #3
Right Turn
Old 06-05-2003, 08:56 PM   #4
Neutral from rear
Old 06-05-2003, 08:57 PM   #5
Left turn from rear
Old 06-05-2003, 08:57 PM   #6
Right turn from rear
Old 06-05-2003, 09:24 PM   #7
Motorman's Avatar
check to make sure the screw that holds the battery pack bracket to the chassis is not rubbing the bottom of the arm. Been there done that.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 06-05-2003, 10:35 PM   #8
Thanks Motorman for the suggestion.
I have tried by take out the battery from the car, but it still does it, so it not that. Any other suggestions?
Sami
Old 06-05-2003, 10:37 PM   #9
Manticore's Avatar
R/C Tech Charter Subscriber
Sami
check your whole steering system from servo to knuckle. you might want to dis-link the tie rod to check or blinds.
Manticore is offline   Reply With Quote
Old 06-05-2003, 10:44 PM   #10
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
Make sure you have the proper spacer for KO 2143, seems like your servo is kind of too far out, towards the outside so when the servo turns the whole tie-rod become an angle and that's why you have blind spot! try use a thicker spacer to move the servo in towards the fuel tank by doing that your tie-rod will more or less prependicular or a 90 degree angle with the steering block when it is dead center!
it might help!
Ah10 is offline   Reply With Quote
Old 06-05-2003, 10:50 PM   #11
Thanks Manticore.
I have taken the tie-rod off the servo but it still does not? How long should I have the steering rod be?
The following is a photo of mine:
Old 06-05-2003, 10:51 PM   #12
Another question is the tie-rod.
Is it ok to different lengths for the tie-rods? or is it a bad thing?
Old 06-05-2003, 10:52 PM   #13
Oops sorry the two pictures are meant to other way around.
Old 06-05-2003, 10:53 PM   #14
Manticore's Avatar
Thanks Manticore.
the tie rod should be in equal length !!
your servo horn should position dead upright and your steering post arm (the arm that connected to the servo) should be pointing dead right and you should set your tie rod from there.
Old 06-05-2003, 10:54 PM   #15
Ah10's Avatar
I believe both of them should be the same length, 25mm (rod only), and make sure each side have the same distant(front knukle to the chassis) that will affect the your alignment too!
m11 Not Centering ? youngie Radio and Electronics 13 09-15-2008 06:43 PM
Centering Steering Servo's hierog Electric On-Road 3 04-14-2006 11:00 PM
Steering Centering Problem A3 Nitro On-Road 22 02-02-2005 03:32 PM
JR-R1 Radio Steering Wheel Not Centering ttektek Nitro On-Road 2 05-18-2003 10:55 PM
