difference: 720 and '07 720
what is the different between the Serpent 720 and the 07' Serpent 720
The new main features of the Serpent 720 '07 are the inclusion of front CVD shafts, extra one way front shaft with lock set, nylon adjustable pivot ball nuts, upgraded fuel tank with o-ring sealed AFL lid, servo saver with adjustable Ackerman, new hard plastic suspension parts and a new black anodised chassis plate.
As an added extra, the Serpent 720 '07 comes with the previously optional front one way system as well the one way lock set to make it into a solid axle, ensuring your car will be ready for all conditions.
A direct replacement of the original servo saver, this new version allows the user to easily adjust the cars Ackerman through the use of inserts thus eliminating the need to remove the entire assembly.
The car comes with 3 completely new, narrow, low friction Kevlar belts.
Check out the very informative website nitrokb.com. It got the info you need plus more!
http://nitrokb.com/720/index.html
