Old 11-21-2007, 08:22 PM   #46
ESWLFSE's Avatar
Send a message via Yahoo to ESWLFSE
I guess one of those will be going on my next order. Hopefully this will be the last one before I get the cars built/rebuilt and running. This is getting awfully pricey for not even having hit the track yet.
ESWLFSE is offline   Reply With Quote
Old 11-21-2007, 08:31 PM   #47
Team Kamikaze's Avatar
But it does like you are definitely enjoying the hobby!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-21-2007, 08:51 PM   #48
ESWLFSE's Avatar
Yup and I can't wait to get behind the wheel again. I parking lot bashed 1:8 on and then raced a PB Phoenix a bit in Chicago years ago until a local WI off-road track opened. Loved that for quite a few more years with an MBX4except for the filth maintenance and the umpteen other classes between every heat but I won the club championship one year. Helis have been entertaining for a few more years now but they are a solo activity. Racing really did it for me and 1/8 on-road was the best. I remember being so wound up on the stand that I couldn't walk and almost fell down the steps after a good heat.
Old 11-21-2007, 09:03 PM   #49
Originally Posted by ESWLFSE View Post
Thought of another question. What is preferable - the little OFNA glow driver panel in the start box or the rechargeable c-cell igniters? I'm leaning toward the driver since I hate dead and dropped igniters as much as charging them but most pics I see show people using the igniters?
K/E?
They are both good, it is just a matter of preference, the OFNA glow drive panel will always be there when you need it, provided your 12 volt gell cell is fully charged all the time, and the c cell or d cell igniters are always good to have as a back up, so if I were you I will have both
Old 11-21-2007, 09:04 PM   #50
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
I scored a few sets of orange GQ 37s on EBay for $27 each.
Yup, I grabbed the last set of K/E 37s that they had, too. Good for setup and practice, but it's not going to last me a whole race season.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 11-21-2007, 09:08 PM   #51
ESWLFSE's Avatar
K/E?
Old 11-21-2007, 10:47 PM   #52
P2gee's Avatar
Originally Posted by flack View Post
In 2006 1/8 Nationals, some drivers were using tires by Lightspeedrc that had black rims. However, I do not think the site still exists.
Doug
Yep.... this is correct, the black wheels some of us used at the 06 Nats were from Lightspeed RC aka Trackside Hobbies. I know these guys personally and i'm not sure but believe they are not participating in the tire/wheel biz anymore. If I get a chance to talk to them in the next few days, I'll see if I can find out.
Airtronics M-12
BYRONS Gen2 fuel
Capricorn C802
www.motorists.org
P2gee is offline   Reply With Quote
Old 11-22-2007, 08:11 AM   #53
ssc-rc's Avatar
K/E?
Hobico make a bunch of igniters in different sizes.That what I use.I have not seen more than 1 or 2 people use the lead type of igniter I guess that would depend on how strong your bump box battery is.
ssc-rc is offline   Reply With Quote
Old 11-24-2007, 12:22 AM   #54
ESWLFSE's Avatar
Can someone explain tire management please?
I understand that you want to start with 1 degree of camber on the rears and the correct sizes F & R (and overdrive) but how do you manage their use?
Do you make the absolute minimum cut F or R plus the rear camber cut on a new set or do they get cut down to a more race-ready diameter right away?
Do you run the fresh cut tires for practice until they wear down a bit?
Do they ever see a truer again during their lifespan or do they wear fairly equally F to R, and if so often?
Is there an ideal size that they reach where you put them aside and save them for a main?
What is an average lifespan for a set of tires in minutes of racing?
Is the finish left by the carbide cutter good enough or do you hand-finish them further somehow?
What is used to cut the radiuses by hand on the truer? Sandpaper? File of some sort?
I'm trying to determine what my tire needs will be and how to be as economical with them as possible.
Thanks!
Old 11-24-2007, 06:12 PM   #55
As it relates to tire management, you've asked several good questions, but the answers are somewhat of a preference to the driver and dependent upon the track, so the answers may vary..
I'll list a few of my preferences..
The starting "pre-cone or camber" to me is simply a way to get the tires as close to a "pre" race run-in, which eliminates several laps of warm-up before the tires "come-in".. Therefore the degree of pre-coning or camber, is based to some degree on what my car comes off the track at... I typically will run a 5 minute practice and then set the cone angle of the cutter close to what the tires came off the track after the practice. Might be 0.5, 1.0 or 1.5 depending on the track or set-up of the chassis. If the tire comes off the track at 1.0 degree of run-in camber, then I set the tire truer up to "replicate" the run-in angle on a new set, in an attempt to shorten the time it takes for the tires "come in"..
The tire size is also dependent on several variables, largely based on tire wear... When traveling I usually set the car up with the standard suggested size by the manufacture, in my case Serpent 960 (74mm Rear, and 68mm Front). The 6mm split is roughly a 2% overdrive, however, the size allows me to practice and begin adjusting the chassis set-up with a medium sized tire (not the smallest and not the largest possible).. After a few tanks of practice I'll re-measure the tires to determine the amount of tire wear.. This is important to me based on the length of time the mains will be run (back to this in a moment), if your parking lot bashing, start with the tires out of the box (big), get all the use of the foam you can.. If your qualifying, smaller tires is usually the fastest (lower car or CG, more traction and lower gear ratio/roll-out, can be quicker)..
However, for the mains, you'll need to understand how much tire wear you expect to see during your race.. For example, a 30 minute main.. If during your 5 minute practice sessions you notice 0.5mm tire wear, then it's possible you could see as much as 3mm of tire wear during your main. This will let you know how big or small you can begin your main, with lower usually faster, it will let you know how much ride height you need at the beginning of the main to allow for the 3mm of tire wear at the end of the race without dragging the chassis in the corners or under acceleration. This information will let you know what tire size to begin practicing and tuning your set-up along with your 2-speed which changes shift points based on tire size :-) SO, while your thinking about that, also keep in mind that all 4 tires rarely wear at the same rate, therefore you may account for each tire separately for a 30 minute main... Based on a clockwise track (potentially more right turns), you may have the left tires wear faster than the right tires, and require more "stagger" from left to right at the beginning of the main..
Overall, with the amount of change in handling, shift points, clutch and motor variation due to tire size... I practice with tires close to the size of half the race of the main... So, in our example from above, if I started with 74/68, and calculated 3mm of tire wear for the race, I would practice with roughly 72.5mm rears and 69.5mm fronts (roughly the wear at half the race or 15 minutes). This would allow me to set the cars chassis, clutch, 2-speed and motor tune at the mid-point or optimum run condition... When I start the main, the car won't be perfect, nor when I get closer to the end of the run, but during middle or most of the run, it will be where I practiced/qualified...
I use a truer quite often on the same set.. Typically, my race set is trued from the box for the main today, and then is re-trued for next weekends practice/qualifier set... After practice the next weekend, I bring out a new box and re-true for the main. Then the cycle starts all over again.
I start the main on the ideal size, ever thing else is used for practice/qualifying.
Average life span is entirely dependent on the track surface, traction compound and your driving style.. A local track in the area has worn up to 10mm in a 30 minute main, while the same or other tracks have worn 2mm during the same 30 minute main at differing times.... Tire wear is largely about the track...
Any finish from the cutter will likely be a mute point within 5 minutes of running... From the example above, if you're using 0.5mm of tire wear in 5 minutes... Then the finish really only needs to better than 0.5mm in pitting to be great in 5 minutes :-)
The radius is usually cut with a file, they have several "special" files, or a simple rasp from your hardware store. I'd think sandpaper is fine to use, but it may take a little longer and get clogged faster for 1/8th tires.
Economics and 1/8th scale is a very tough balance. When I began, any old tire or size would do (I really didn't know or could tell the difference), as I got a little faster I began to find speed in the tires, primarily around fine tuning everything else (chassis, clutch, 2-speed and motor).. Using my medium race set (not to big not to small, but good for the size of the middle of the main), it allowed me to "set-up" the car for the sweet spot of the main, and allowed me to tune the other aspects, which helped me gain a 0.01 here or there... After finding a few of those "tenths" it became a "second" faster and so on...
Darint is offline   Reply With Quote
Old 11-24-2007, 06:28 PM   #56
Serpentd's Avatar
WOW DarinT, That was an EXCELLENT write up about tires. I was going to try and answer that (those) questions last night, but said to myself...this is going to take some time. So dude, A+ for your tire write up. VERY VERY GOOD!!!
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 11-24-2007, 07:24 PM   #57
ESWLFSE's Avatar
That was a fantastic reply Darin and that info will help me out a lot. Thanks for taking the time! I'm stuck here in WI with zero resources except RCTech and I want to have a car as race-ready as it can be when I move to Tampa in Jan.
Old 11-24-2007, 07:46 PM   #58
first off grate thread, I two am going to get a 1/8 scale for the 2008.
I am no stranger to onroad racing 3 hours from 301 in MD ran turing car V1rrr 6 times or so. (things to do before i die run 1/8 scale onroad) so to the point
should I what to get the new K m3, go serpent, or just get the K evol wc and call it a day
what restricter size should be run on them 6mm 7mm 8mm thinking of going with a os
p.s stuck running off road 1/8 onroad is where the hart is (and yes spelling sucks) thanks
8lackflagracing is offline   Reply With Quote
Old 11-24-2007, 09:30 PM   #59
Serpentd's Avatar
Dude, no...you need a Motonica with the RB Xenon R. If you want to race 1/8th scale before you die, You just as well get the best right off the bat! I've raced at 301 2 times and it's a KILLER track for sure. So yeah dude, Motonica and Xenon R.
Blessed are the SIC
Old 11-24-2007, 09:52 PM   #60
I may need parts again I am a racer 13 years ontrack do you have a wed sight for this car
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 1168 11-23-2017 08:19 AM
OFNA 1/8 Scale Thread Lost Racer Electric Off-Road 9 07-01-2011 05:32 AM
Northwest Racers General Discussion Thread Desolas Northwest Racers 23 02-14-2008 03:17 PM
‘Official’ On-Road racing of 1/18 scale Off-Road Vehicles Thread imjonah Micro and Mini Scales 13 10-10-2007 08:45 AM
1/12 scale thread highwayman Electric On-Road 2 04-19-2003 05:30 PM
