Old 05-29-2003, 11:39 PM   #1
ottoman's Avatar
R/C Tech Charter Subscriber
Default Ofna/Pico 7 port... Any good?
I just picked up a new Ofna Pico 7 port, cheap. I have never read anything about these motors. How do they rate against the NovaRossi based Motors?
ottoman is offline   Reply With Quote
Old 05-29-2003, 11:58 PM   #2
Manticore's Avatar
Manticore is offline   Reply With Quote
Old 05-30-2003, 12:38 PM   #3
ottoman's Avatar
Manticore... Thanks for the info, but how does it compare, for instance, to my RB 5 port in reliability and performance?
Old 05-30-2003, 12:56 PM   #4
Manticore's Avatar
I prefer RB 5 port..........
Old 05-31-2003, 12:01 AM   #5
popsracer's Avatar
Guys;
As with all Picco based small blocks, the secret to making good Power is using a Novarossi Carb (If your rules allow it). I also recommend REMOVING the THIN head shim out of the 2, no matter what % of Nitro you run (well maybe not with 40%)
All of my Piccos have always run great this way.
I also have a Brand New Ofna/Picco 7port in the box (NOT 4-sale), but my Standard 3 port XP runs so good, I haven't had any reason to use it yet.
popsracer is offline   Reply With Quote
Old 06-01-2003, 02:27 AM   #6
Old Skool's Avatar
Default Re: Ofna/Pico 7 port... Any good?
Originally posted by popsracer
Guys;
Hmmm...interesting. I run mine with a spare MT-12 slide carb, and have added a second shim. I use 30% O'Donnell fuel. The tip was passed along to me after personally witnessing an experienced tuner struggle for almost 3 hours trying to get his 7-port to run properly. He had the Novarossi carb but didn't do the shim thing. Finally he added a second copper head shim...*boom*, engine fired right up and ran great the rest of the day. Maybe I'll remove a shim and try it...
But FWIW, my RTO is still quicker.
Old Skool is offline   Reply With Quote
Old 06-01-2003, 09:11 AM   #7
ottoman's Avatar
Thanks for all the info.... does anyone know of a place online that sells head shims and other engine parts? I have no LHS so I have to find everything on line
Old 06-01-2003, 11:35 AM   #8
Old Skool's Avatar
You can use head shims from any Novarossi-based .12 engine. I usually get all my stuff from Ace Hobbies:
www.ace-hobbies.com
Old 06-11-2003, 09:18 PM   #9
Default popracer picco
hey popracer do you use nova carb and the extra shim on your three port also ,what fuel do u use and what car areu driving.
isuzuguy is offline   Reply With Quote
Old 06-12-2003, 09:28 AM   #10
popsracer's Avatar
Default Picco Engines
isuzuguy;
I haven't ran the 7 port yet, my 3 port XP runs so good.
Picco 12XP, Novarossi slide carb, Trinity MH 30% fuel, removed the THIN head shim, running a Reflex NT.
Old 06-12-2003, 12:16 PM   #11
ottoman's Avatar
Pop's... what do you run for a exhaust manifold? The Picco exhaust is smaller than the NovaRossi type motors and most pipes I find are for the larger style.
Old 06-12-2003, 07:03 PM   #12
Arun's Avatar
That "7" port engine annoys me. The engine really has 5 ports, like all the other outlaw small blocks. The extra two "ports" are just dummy holes in the sleeve.
I have never run one, but i have seen one. Sure, it has exceptional power. I am not downing the engine's performance, by no means. It just annoys me that ofna added two dummy ports to get attention.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 06-12-2003, 09:04 PM   #13
Registered User
OB42TC3's Avatar
Default Re: Re: Ofna/Pico 7 port... Any good?
Removing the shim and it may go quick .. for about 3 minutes; really depends on the fuel; on OD 30 you probably need the shim; I know I did on my collari 3 port.
OB42TC3 is offline   Reply With Quote
Old 06-12-2003, 11:39 PM   #14
You are very much mistaken. They are not dummy ports. They are not part of the transfer port system, but they do serve a purpose. They work as part of a by-pass port system that helps to scavenge extra fuel into the motor. All .21 on road motors use some sort of a bypass port system. Most of them have port in the piston to to help out as well.
BTW ofna did not even add the two bottom ports you are talking about. The colari 5 port, which this motor is based off of, uses the top transfer ports and the two bypass ports under them to make it a 5 port motor. Ofna has the motors made with the two corrector, slot, ports added in to make it a seven port motor.
JPHRacer is offline   Reply With Quote
Old 06-13-2003, 01:15 AM   #15
Arun's Avatar
...I stand corrected
Boy, that makes me feel stupid. j/k thanks for the insight.
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
Pico .28 9 port P3 vs. Jammin .28 Off-Road teeforb Nitro Off-Road 20 10-02-2007 12:37 PM
Ofna Picco .21B 3 Port engine, good budget engine Cain Electric Off-Road 1 03-26-2007 08:32 AM
ofna pico .12R inline pipe and manifold CRT_MAN R/C Items: For Sale/Trade 2 08-28-2006 06:05 PM
Werks P3 Same as OFNA Pico 26 and Orion WASP 26 KansasCajun R/C Items: For Sale/Trade 14 01-14-2005 02:54 PM
