Old 11-10-2007, 11:54 PM   #1
ViperSkull's Avatar
Default And this is what happened to my JP-FX3 Piston
I have no idea how this happened. I did look at my engine bearings and one of the balls in the main bearing looks like it has split in half so that might have caused it. I'm so annoyed as this piston is only 3 race meetings old and the bearings are 1 race meeting old.
[IMG][/IMG]
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
Old 11-11-2007, 12:04 AM   #2
Team Kamikaze's Avatar
Did you just installed a new rear bearing? if you did which brand and what kind? is it an original bearing? what happened to the original bearing? (that is if you just replaced the rear bearing)
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-11-2007, 12:06 AM   #3
ViperSkull's Avatar
Yes i did replace the rear bearing with a new rear bearing. thats why i said it was only 1 race meeting old. and it was the proper JP FX bearings specifically for that motor
BRCCC Wynnum
Old 11-11-2007, 12:09 AM   #4
part # 16602C ?
Old 11-11-2007, 12:14 AM   #5
RevMaxx's Avatar
Send a message via MSN to RevMaxx
aww!!! that's too bad...
if you say its the bearing balls, it looks like it went up the combustion chamber through the intake port but got stock on the sleeve as the piston pushed up and scraped the piston, and i believe same thing happened to the sleeve as well...
ohh well, get yourself an early christmas present and get a modified engine!!!
RevMaxx is offline   Reply With Quote
Old 11-11-2007, 12:30 AM   #6
ViperSkull's Avatar
I just took the Rear bearing out and had a look and one of the balls has a chunk taken out of it. so depressing
BRCCC Wynnum
Old 11-11-2007, 12:31 AM   #7
ViperSkull's Avatar
Originally Posted by Team Kamikaze View Post
part # 16602C ?
Yes, part number 16602
BRCCC Wynnum
Old 11-11-2007, 08:19 AM   #8
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Default hmm
where can i get that part
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 11-11-2007, 10:51 AM   #9
Next question.......how did you install the bearing??
JVStrat is offline   Reply With Quote
Old 11-11-2007, 12:46 PM   #10
Canuck's Avatar
Trader Rating: 25 (100%+)
Was the rear bearing installed using the proper tools ? It may not have been properly seated.
Canuck is offline   Reply With Quote
Old 11-11-2007, 01:13 PM   #11
srsracer's Avatar
Angry
holy crap http
srsracer is offline   Reply With Quote
Old 11-11-2007, 03:01 PM   #12
Moderator
mxwrench's Avatar
I assume the bearing you installed had ceramic balls. Is this correct?
Ceramic bearings, allthough extremely hard, are extremely fragile. Any impact to the bearing can cause the balls to crack, split, or shatter. So if this bearing was subject to impact of any sort (ie. hammering into the crankcase, or even falling off the workbench) this would be the cause of the failure. Extreme care MUST be used when handling these special bearings, and if there is any doubt that the new bearing has been subject to impact it MUST be discarded and replaced.
The proper method of installation of ceramic bearings is critical to avoid such problems.
The best method is to heat the crankcase to roughly 250 deg. F. and refrigerate the bearings prior to installation. Then simply drop the bearings in place. They should slip right in to their final position in the crankcase easily. This technique does require some skill that the bearing is not accidentially allowed to slip in crooked, if it is it can get stuck. This will require the bearing to be PRESSED back out and recooled for another try. IN NO CASE SHOULD YOU HAMMER THESE BEARINGS IN OR OUT OF THE CRANKCASE!
The next best method would be to use a pulling tool to draw the bearing into positin in the crankcase. This is quite easy but does require some special tools. These tools are available from Novarossi and other sources.
The last method I would reccomend, but as a last resort is using a press. The only downfall tho this method is the possibility to push the bearing in a little crooked and the race can actually gouge the bearing surface in the crankcase. This can build up a slight amount of material from the crankase behind the bearing race and not allow it to seat completely. Also the bearing can be off axis if this happens causing running or performance issues.
Good luck on the next engine, and remember to treat ceramic bearings with the utmost care when handling and installing. They are a great product but must be dealt with carefully.
BK
[IMG][/IMG]
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 11-11-2007, 08:31 PM   #13
16602 without a "C" is not a ceramic bearing.
What happened to BYT?? salteen Chat Lounge 2 03-17-2008 05:04 PM
Has this ever happened to anyone? sho .21 Monster Trucks 8 03-19-2006 03:25 PM
Light Oil & Small Piston Hole vs. Heavy Oil & Large Piston Hole Rich Panganiban Nitro On-Road 2 01-26-2006 04:24 AM
what happened to 9rc.com kimi Malaysian R/C Racers 14 07-25-2003 09:29 AM
OK, what happened? Speedo R/C Tech Site Forum 45 09-04-2001 07:18 PM
