Old 11-09-2007, 11:59 PM   #1
Default Please help asap.....MTX-3 issue
I started to run my MTX-3 today and it acted rellay wierd.
When I let off the throttle it seems as if the brake was being applied. I checked the linkage (all good) so I thought it was spool messing up. Put the front diff back in and still did it. I then changed the rear diff and still did it again. I even removed the brake and still did it.
I checked all the bearings and they are good.
When I remove the main belt (left side) it rolls great with no binding. Once reinstall the belt the rear tires seem really tight when I tr to roll it. You can see that rear wheels are binding a little. But it only does this when the left side belt is on.
I am clueless on this one...........
Any help is great.
rc_freak is offline   Reply With Quote
Old 11-10-2007, 12:32 AM   #2
asw7576's Avatar
Assuming that your brake is truly free when off throttle position.
I would consider these things :
1. Increase the height of rear upper link on the rear uprights, like 3mm height. Use longer screws.
2. Use fresh tires <--- very important.
3. Set rear downstop to 4 and front downstop to 0 on Hudy block
4. Remove the rear stabiliser, or simply use thin rear stabiliser.
5. Set front track width and rear track width = 200mm
6. Set rear camber position to 4.0 or 4.5 degree inward.
7. Use B rear block.
8. Follow the setup manual as starting point. ( ride height, oil viscosity, camber, springs, etc ).
Old 11-10-2007, 05:41 AM   #3
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Kinda sounds like a pulley is in the wrong spot and its trying to overdrive the rear wheels.
When you remove the side belt is the rear bound up aswell or is it only when you put the belt back on?
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 11-10-2007, 07:12 AM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
Are you sure the side belt is not rubbing on the exhaust manifold? Check your belt tentioner
lil-bump is offline   Reply With Quote
Old 11-10-2007, 10:19 AM   #5
As for the side belt. I even took off the pipe and the belt ten. and still does it.
All ride hights ect. are good
As far a pulley being the wrong size, it is poss. What sizes are they on the two side ones for the side belt.
Old 11-10-2007, 01:15 PM   #6
lil-bump's Avatar
It maybe 16 rear 19 forward if it has the pulley conversion. Not sure what stock is. Does the car drag when rolling forward or reverse? Do you have a one-way installed up front or a diff. This will determine if the problem is in the rear or front. Check all your bearings
Old 11-10-2007, 01:33 PM   #7
Taylorm's Avatar
Any help is great.
.......something up front is binding.......you said bearings are OK.....are driveshafts bent?,binding at diff or axles?? do front wheels spin freely with axles removed? does car have a one way up front?.. is it spinning freely and locking???????????
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 11-10-2007, 03:14 PM   #8
Hey guys. Thanks for all the replies and help.
I called the guy who I bought the car from and it does have the pully conv. on it.
The two side pullies were swithed.....I was so stupid not to catch it....lol
Anyway, I switched them and rolls smooth as ever.
Thanks again everyone.
*ASAP* NEED REAR HUBs FOR 1/12 THATS 3 BOLT *ASAP* we R/C Items: Wanted to Buy 1 10-06-2007 10:50 PM
FUTABA 3PK ( with mod & rec. ) must sell asap...and more...LOOK..must sell asap. rc_freak R/C Items: For Sale/Trade 16 03-21-2007 10:21 AM
XXX-S Issue Sweeney921 Electric On-Road 18 01-22-2007 08:07 AM
DPD issue Racingfreak6 Electric On-Road 5 01-01-2007 09:56 AM
OS .12 5p issue Black_Widow Nitro On-Road 4 12-18-2006 10:19 AM
