Old 06-03-2003, 10:01 PM   #16
EdwardN's Avatar
Default Re: Re: Engine vs Engine Power output
Originally posted by PMT
Popsrace, it's the same. I have visited most of the engine manufacturers in Italy and when looking at their teams "race engines" one thing realy suprised me. This is how stock they look. There usualy is verry little modification done to them with the exception of some minor crank work and clean up on the case / sleeve. I asked about this and what I found is that when they build team engiens what these guys do is pull 100+ engines and measure every single component in the engine. What they do is pick only the pieces that have the tightest tollerences i.e. perfectly round sleeves, super straight connecting rods, cases where the crank bearings are perfectly alligned. So out of the 100+ engines they start with they end up with the components to make about 15 perfect engines. These 15 engines are then assembled and tested on the dyno and on the track by the driver. Out of these he will usuay end up with between 5-10 engines that are realy good. These are cleaned, oiled and bagged for use by the driver over the season.
Heres some food for thought. When you buy something like an RB Team engine which is broken in and tested on the dyno at a premium of $100+ over the non team engine. Do you realy think that you are getting the best ones?
Very interesting discovery for me! Is it realy happened like that? So it means most of the guys- non team drivers-are competing on the same engines as a team drivers?
EdwardN is offline   Reply With Quote
Old 06-03-2003, 10:08 PM   #17
mckrooz's Avatar
Send a message via AIM to mckrooz
Well that sux. We just bought that engine for my brothers V-One R hoping to kick some butt at the track. I'm pretty dissapointed. They were waay off on the ratings.
mckrooz is offline   Reply With Quote
Old 06-03-2003, 10:22 PM   #18
PMT
Default Re: Re: Re: Engine vs Engine Power output
It means that most of the non-team guys have the same basic engines as the team guys. Notice I said basic, as you know all of the power comes form the details.
PMT is offline   Reply With Quote
Old 06-03-2003, 10:31 PM   #19
EdwardN's Avatar
Default Re: Re: Re: Re: Engine vs Engine Power output
You right! This is the way has to be! If company wants to sell its product-the team has to use the same base, details-it is up to the mechanic and racer. I was wondering if the way how they select engines ( in the factory team) that like it was explaned earlier? They have to run 100 engines and choose 10 out of them?
Old 06-04-2003, 03:27 PM   #20
popsracer's Avatar
Default Have a chuckle about power claims
Guys;
I have heard and always suspected that Factory supported Drivers have access to the best equipment (and why not). It is certaintly evident in Electric, especially with batteries.
Just wondered if anyone had seen radical differences in identical (store bought) Nitro Engines before.
Just got to say that I'm glad NOT to be a Pro Driver, too much StReSs involved! (at my ripe old age)
Thanks,
popsracer is offline   Reply With Quote
Old 06-04-2003, 08:28 PM   #21
Motorman's Avatar
YES
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 06-04-2003, 08:33 PM   #22
Motorman's Avatar
true and false. Your talking before they leave the factory, which is not insignificant.(hand picked assys) Its what happens after they leave and no matter how many times Pieter Beroviets tells me their team engines are stock I have eyes and have seen Michael Salvins 21 splayed open at FT Myers and so who is he kiddin. I can tell you the US guys that run for Novarossi get just the hand picked stuff. Like I said its the what happens after that that makes a huge difference.
I have some of those Quote stock factory team engines comming this way right now for a quote factory guy that runs a quote factory stock engine. LOL
Old 06-04-2003, 09:45 PM   #23
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Being an unhappy veteq owner...I wouldn't believe anything that comes out of pieters mouth..
theres a reason a Serpent has a forked tongue....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 06-04-2003, 09:45 PM   #24
fastharry™'s Avatar
Old 06-04-2003, 09:48 PM   #25
mckrooz's Avatar
Default Will this adapter work with the Orion Wasp carb?
Old 06-04-2003, 09:48 PM   #26
mckrooz's Avatar
It's the carb adapter from Hardcore made for the MT12.
Old 06-04-2003, 09:59 PM   #27
Motorman's Avatar
Harry
Like emeril sez !BAM
I feel fer you dude. I resisted the temptation when that thing came out, and took alot of heat from naysayers. Technically cool, technically a nightmare.
Old 06-04-2003, 11:59 PM   #28
SlobbaTech's Avatar
There was an article in the latest Xtreme or R/C Car where Drake used the Lunsford adaptor to put an OS carb in his Picco, they also said the Hardcore one worked. The Lunsford one should be better since the shoulder isn't as thick as Hardcore's keeping the carb closer to it's intended height.
SlobbaTech is offline   Reply With Quote
Old 06-05-2003, 08:56 AM   #29
popsracer's Avatar
Default Carb Adapter for Picco (wasp)
The I.D. on the Carb Throats is the same on Picco and Novarossi engines. I use NR Carbs on my Picco's all the time, so either adapter should work fine.
Old 06-05-2003, 07:37 PM   #30
mckrooz's Avatar
Ok, good. Cause this carb is a pain to tune. We can't even get it running for more than 10 seconds. Gonna try and put an O.S. carb in.
Video: Mexican Consulate Claims San Diego Will Return to Mexico‏ Leodis Chat Lounge 5 03-17-2008 10:40 PM
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
Novak N-Power 14Volt/10AMP DC Power Supply Guo Chean R/C Items: For Sale/Trade 6 04-23-2007 05:32 PM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
Novak Millenium Pro charger ans N- Power power supply RobertF R/C Items: For Sale/Trade 11 11-27-2005 08:59 PM
