Old 05-29-2003, 02:24 PM   #1
Default How to glue foan air filters back to its base?
have a few foam air filters were the foams has came unglued at its base. can you glue them back with something?
Columbus is offline   Reply With Quote
Old 05-29-2003, 02:41 PM   #2
VoneRkid's Avatar
Default Re: How to glue foan air filters back to its base?
I use contact adhesive (Magic) to fix my air filters
Damo
VoneRkid is offline   Reply With Quote
Old 05-29-2003, 04:17 PM   #3
AMGRacer's Avatar
They are cheap so I would not bother, just buy a new one. If you do not glue it up right you risk a "dirt leak" ruining a $150 engine for a $5 filter.
AMGRacer is offline   Reply With Quote
Old 05-29-2003, 04:32 PM   #4
VoneRkid's Avatar
You should go and buy a motor saver air filter there around about $20 AUS it is the way to go
Damo
Old 05-29-2003, 04:57 PM   #5
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Re: How to glue foan air filters back to its base?
Great point! I totally agree with. Moreover, some engines nowadays do cost as high as $500, a Japanese Moded .12, for instance.
Check the filter regularly, and replace it at once when see any torn/worn.
eddiethefish is offline   Reply With Quote
Old 05-30-2003, 12:33 AM   #6
rrgt_kid's Avatar
just buy a new one!!!
i use the motor saver filter gaind alittle performance and then
it has saved me heaps in filters!
rrgt_kid is offline   Reply With Quote
Old 05-30-2003, 05:21 PM   #7
Im2lazy's Avatar
Yeah, I like the motor savers filter better than those other type foam filters. It has a pretty good prefilter as well as replaceable foam elements. Also, I feel it is easier to clean and detect when you should replace the foam elements as they are white rather than black.
Im2lazy is offline   Reply With Quote
Old 05-31-2003, 10:10 AM   #8
popsracer's Avatar
Default Motor Saver Filters
Guys;
The thing I like about the Motor Savers is the Screen on the outside keeps the dust from infiltrating the cells of the Foam. There is just no way dirt/dust is going inside that Engine with a Motor Saver.
5 Nitro vehicles (and counting) and EVERYONE of them has a Motor Saver.
popsracer is offline   Reply With Quote
air filters mixedguy Nitro Off-Road 41 08-06-2008 02:59 AM
How to remove CA glue? CA Glue on T2R chassis mcgmark Electric On-Road 18 09-27-2006 08:58 AM
Can I use ELMERS glue to glue my tires to the rims? Jhyten Electric Off-Road 20 02-25-2006 11:49 AM
Air filters TouringMaster Painting, Designs, Graphics and Photography 3 03-27-2005 05:43 PM
Air Filters nitro rookie Nitro On-Road 4 04-04-2004 11:19 PM
