Old 11-04-2007, 11:45 AM   #1
Default Belt Drive vs shaft drive
What is the benefits of belt drive vs shaft drive ?
vic88my is offline   Reply With Quote
Old 11-04-2007, 12:22 PM   #2
Rawz's Avatar
A better weight distribution, I think. With a belt kit, the suspension geometry is more simetrical, no ?
Rawz is offline   Reply With Quote
Old 11-04-2007, 12:42 PM   #3
Little_Mike's Avatar
yay i love these threads1
all the top cars have belts. shaft drive is simple, tough, and buttery smooth, however belt drive seems to be the top choice for onroad since fouling of the belts is a non issue in onroad. but offroad 4wd cars use shaft drive cus its tough and sealed so it dosnt get very dirty.
R.O.A.R. region 11 stock rubber carpet champion
Sponsored by: Hot Bodies
HB Cyclone Moore Speed WCE Edition - HB/BMI Cyclone(foam)
Team Magic G4RS pwered by EB mods and O.S. engines
Little_Mike is offline   Reply With Quote
Old 11-04-2007, 01:20 PM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
It is all about the power of the motor. Simple science formula: Action = reaction.
The power that the motor can produce will also create a negative action on the housing of the motor and so in the chassis,
Powering a shaftdrive will give a roll movement in the chassis and can cause an unbalanced/unpredicted steering movement also known as torque steer.
In a betltdrive the reaction power is converted in a way to push the rear end to the ground and so to create more grip which makes the car more stable and balanced in a corner.
Is it noticeable ?
Yes if you are an advanced driver driving the fastest laptimes and no/slightly if you are just driving for the hobby somewhere on the street.
As a parking driver it is wise to go for a shaft, belts are to sensitive for dirt and will give a lot of maintenance.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-05-2007, 04:04 AM   #5
hooked_on's Avatar
Both types of chassis's have advantages and disadvantages. At the moment, belt drive is the flavour of the month with manufacturers.
My advice to you is practice, practice & practice. Work on your driving ability and setup. At the end of the day it comes down to driving ability and your setup... ohh and some luck to stay out of trouble as well "To finish first, first you must finish!"
Best of luck!
- - - - 2013 Dick Johnson Racing Team Mate Member - - - -
hooked_on is offline   Reply With Quote
Old 11-07-2007, 06:34 AM   #6
keavze's Avatar
Best of luck!
yup, totally agree...
i've used my shaft car and beaten all my frd's belt cars. for now at least.
keavze is offline   Reply With Quote
Old 11-08-2007, 08:51 AM   #7
Is it difficult to replace broken belt ?
I wish to buy GS Vision touring car 1/10 which is belt drive.
Old 11-09-2007, 03:07 AM   #8
hooked_on's Avatar
It can be a tricky task depending on the car. I have always found it a challenge, but that might be because i am Noob... I have always liked drive shaft cars as they are easy to work on. Problem with a drive shaft car is the crown gear & pinion is the weakest spot on the car. Also becasue it is right with the diff the extra heat created can cause issues with the diff itself as well.
At the end of the day, it is your driving ability that counts. Get a car that you can get parts from your LHS though.
Old 11-09-2007, 04:03 AM   #9
aussies1129's Avatar
Trader Rating: 74 (100%+)
all the cars that run and win at my local track including mine are belt driven, like anything at first it may be tricky to change your belt but over time you get better and quicker at changing it, also some cars have upgrade h/d belts which should last you a long time I have run my car about every week for about 10mths and it has 3 belts and none have broken yet.
hope this helps
aussies1129 is offline   Reply With Quote
Old 11-09-2007, 05:05 AM   #10
upgrade h/d belt ? what is that ?
Old 11-09-2007, 06:41 AM   #11
upgrade to a tougher belt h/d heavy duty, I got my team magic g4s which came with stock TM belts and this car has the option to upgrade to kfactory belts better quality tougher belts.
Old 11-09-2007, 06:46 AM   #12
correct me if I am wrong but isnt it all about power delivery?better with belts than shaft??I think most of the top cars are belt drive=mugen seiki,kyosho V1RR,team magic g4S/+ any other ??xray??
Old 11-09-2007, 08:19 AM   #13
one major concern that hold me back from buying belt drive car is that everybody is saying that shaft drive is more durable. My place here got about 15% of sand and pebbles on the area.
Is it really that vulnerable as everyone is saying and advising ?
Actually, I want to buy GS Vision touring car. Everyone saying belt drive very sensitive to dust, sand and dirt.
Is it really that terrible for belt drive ?
I don want to spend a lot of money. Now buy belt drive and then next month having to buy another car which is shaft drive.
I don't want any stereotype or subjective opinions.
Old 11-09-2007, 10:57 AM   #14
I believe that FW05T+ is far better car than the GS Vision, and if you're saying that where you run there is a lot of sand/dust, FW05T+ is even better!
Go for it and you won't regreat!
Now there is a new FW06, that comes with a better radio and digital servos, plus some other upgrades. Consider this car too if you can find it.
V1RRR Evo WCTE - Sirio STI/NR 353 MM - Futaba 3PM FASST
FW05TRR - GXR15 Tunned - Futaba 3PM FS Pro
Ramiel is offline   Reply With Quote
Old 11-09-2007, 12:15 PM   #15
Jspeed's Avatar
Get the Kyosho FW05 or 06 or you'll be giving yourself the shaft.
You could also look at the Kyosho Inferno GT car and give everyone else the shaft.
Jspeed is offline   Reply With Quote
shaft drive vs. belt drive plz help pH1L Rookie Zone 1 06-07-2007 05:32 AM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 09:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 07:57 AM
Shaft Drive or Belt Drive? dino.tw Nitro On-Road 109 05-25-2004 11:04 PM
