Old 10-18-2007, 03:53 PM   #1
Seisick's Avatar
Default 4.8v or 6.0 volt
regardless of what servo or receiver i'm using?
whick rx pack will provide longer runtime
a 4 or 5 cell, or the same runtime? considering they have the same capacity
and the fact that my servos will be slower and less torque
just wondering from all weight freaks in my club
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 10-18-2007, 03:57 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPCR8
you will need this too!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJF6
Old 10-18-2007, 04:40 PM   #3
JetMD's Avatar
With the same Mah, if you consider just voltage, the higher voltage will last longer. This is because the servos won't use up as much voltage because they don't have to work as hard as they would with lower voltage. Think of it as horsepower. With more horsepower, the engine doesn't have to work as hard to move the car which will increase mpg as well. I would think there would be a big difference in the performance of the servos too. If you're used to them running fast, switch to lower voltage to save a gram, then smash the wall because the servo didn't turn fast enough, it's not really worth it. Plus, you spent all that money on that motor and don't you want to see it run to it's full potential? With a slow servo, it won't and that gram you saved on a battery is causing you to get smoked out of the corners.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 10-18-2007, 05:59 PM   #4
Seisick's Avatar
but won't faster and torquey drain more? forget about the performance on the servors, just strict to which will provide more run time!
HobbymaniA
GoT MuGeN?
Old 10-18-2007, 07:46 PM   #5
avs
avs's Avatar
Originally Posted by JetMD View Post
With the same Mah, if you consider just voltage, the higher voltage will last longer. .
actually i believe the opposite to be true. with the higher voltage available the servo will draw more current (servo is a constant resistance, so an increased voltage means higher current flow) it seems non-intuitive.
despite the reduced run-time, the increased speed and torque will more than offset any run-time disadvantage.
avs is offline   Reply With Quote
Old 10-19-2007, 03:15 AM   #6
Seisick's Avatar
so basically if you have enough juice on your servos and assuming that they re not digital (more currente draw right?) a 4.8v will provide more runtime! i guess this question could be easily answered if somehow i could now what is the draw in mah per hour at 4.8 or 6, the same info for a servo for example torque and speed at 6v.
thanks
HobbymaniA
GoT MuGeN?
Old 10-19-2007, 07:34 AM   #7
ALG
Go with LiPo packs, they work great, constant voltage (with the regulator), light weight, and more capacity for weight ratio.
son buenas (they are good)
the most import thing, HAVE FUN with the experiments
ALG is offline   Reply With Quote
Old 10-19-2007, 07:55 AM   #8
avs
avs's Avatar
thanks
hmm, something i forgot to consider, the servo motor's draw is proportional to the torque or it's load. so if you have enough torque with the lower voltage, and you don't change driving style.(don't use the additional torque somehow)
maybe someone has done an experiment, but i think the answer is 'same torque= same runtime' , 'use the higher torque= reduced runtime'.
Old 10-19-2007, 08:33 AM   #9
Seisick's Avatar
oh yeah at $2.9 the 4 pack of 750mah duratrax at tower should be enough to do the experiment, on the other hand, if lipos were to be used without regulator that would be a different story, though some use it directly on their ko rx and servos with no problems whatsoever
lipos son caras jeje
HobbymaniA
GoT MuGeN?
Old 10-19-2007, 09:07 AM   #10
Roelof's Avatar
Send a message via ICQ to Roelof
Lipo is not my choice. We do drive in the rain and I have seen many regulators failing with one drop of water inside. Currently 2/3A cells are very good, I run the IB1400 cells and can run up to 1 hour with no problems on 6v with digital servo's.
These cells are yet available with up to 1600mAh (Team Orion)
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 10-19-2007, 11:21 AM   #11
Seisick's Avatar
yep, in currently using the smc 1200 6v, for over a 16 months now and it provides more than an hour to my digital servos, i just discharge it to 1.1v per cell once a month and so far so good, just wondering cuz if i could save 20g on that pack if i convert it to 4.8v, i've got too much performance already on my servos
HobbymaniA
GoT MuGeN?
Old 10-19-2007, 09:16 PM   #12
Well, i just switched to 6v myself, but i haven't had the chance to really test it. However, from what i gather 6v doesn't really matter if you are running AM and people say it typical last about an hour or two Still, its hard to believe that a 6v 1400mah could outlast 4.8v 2500 mah (energizers cost about 10 bucks, actually cheaper than 6v stick battery). Regardless, I remember running 4.8v 2500mah for about 5 hours (not straight of course). I can't tell you how much power was left out of the pack as I didn't have a volt meter.
a1m80t is offline   Reply With Quote
110 volt fan pecrichard R/C Items: Wanted to Buy 3 12-09-2007 05:14 PM
204 Volt Charger woodsy144 Australia Wanted to Buy 4 12-01-2007 06:48 PM
.01 volt how much does it matter? YmeBP Electric On-Road 7 11-24-2007 10:34 PM
what volt should they be shakzool Rookie Zone 10 08-21-2006 03:23 PM
re-volt (anyone play this) Calvin Ng Chat Lounge 2 10-13-2003 06:08 AM
