Old 05-19-2003, 09:51 PM   #1
Default Will a TRX 2.5 fit in a NTC3?
Can i fit a TRX 2.5 in a ntc3 without modifications ? does it have the same footprint as a small block ? how are these engines compared to lets say an MT12? thanks in advance!
compuatic is offline   Reply With Quote
Old 05-19-2003, 11:04 PM   #2
common guys, someone let me know... also is its shaft a standard SG shaft ?
Old 05-19-2003, 11:19 PM   #3
Ducati998's Avatar
I also own a ntc3, but I think it probably won't fit because the trx 2.5 is pretty big. I could be worng though.
Ducati998 is offline   Reply With Quote
Old 05-19-2003, 11:51 PM   #4
Old Skool's Avatar
No, it will fit. Someone over on the Traxxas Board did just that. It has the same mounting bolt spacing as any small-block .12 or .15, and it uses a short shaft. The owner went a bit overboard and replaced the stock TRX innards with a Sirio 5-port p/s set. He says that the power is absolutely insane.
Old Skool is offline   Reply With Quote
Old 05-20-2003, 05:33 AM   #5
NTC3NUT's Avatar
This was brought up before, if I remember correctly the 2.5 T-Maxx header will almost work on the NTC3. As far as the engine goes, it should go right in. Just make sure you have the right motor mounts & clutch set-up.
NTC3NUT is offline   Reply With Quote
Old 05-20-2003, 09:44 AM   #6
Old school do u have the link on the traxxas board?
also, is the crank on the engine a standard SG? so stock clutch setup will work ? thanks
Old 05-21-2003, 12:14 AM   #7
Old Skool's Avatar
This may help!
http://monster.traxxas.com/showthrea...highlight=ntc3
FT NTC3 and a RTR NTC3 rollers bj4racer25 R/C Items: For Sale/Trade 1 08-03-2007 01:58 PM
Brand new NTC3 and used NTC3 doki_doki R/C Items: For Sale/Trade 11 02-10-2005 10:37 PM
WTB: Centax for NTC3 and FT-NTC3 Roller FFR3582 R/C Items: Wanted to Buy 5 08-09-2004 05:39 PM
Building my NTC3 and bought a MUGEN MT.12 motor for my NTC3..good choice? need advise JDMboy Nitro On-Road 8 08-09-2004 09:31 AM
Ntc3 ImportRacer1187 R/C Items: For Sale/Trade 26 06-04-2003 09:58 PM
