Old 06-25-2010, 09:00 PM   #781
Originally Posted by Chubba View Post
I didnt need to dremel the rear part. the belt clears about 1-2mm.
Please confirm whether this was with the 20T rear pulley (M3) or 22T rear pulley (M3 evo).
Thx!!
mhavlena is offline   Reply With Quote
Old 06-26-2010, 07:35 PM   #782
Thx!!
Nobody ever had to cut the engine block using the 22T rear pulley??
Thx.
Old 07-07-2010, 01:43 AM   #783
Default purchase
attention evolva drivers.
i am loaning my mates M3, and i think it is amazing.
now i want one of my own.
can you please point me in the direction of
1. the cheapest kit on the net (HK or USA or JP)
2. the cheapest and most reliable parts stockist on the net
3. the most important hopups for the car
4. any tips i will need in building/ setting up my new car
all advice will be greatly appreciated
many thanks to all
kurtcash is offline   Reply With Quote
Old 07-07-2010, 02:25 AM   #784
Sp Racer's Avatar
many thanks to all
Brendan sent u a PM
Sp Racer is offline   Reply With Quote
Old 07-10-2010, 07:49 PM   #785
Paulie Bee's Avatar
Default M3/EVO 60-65% OFF Free Ship parts gotta go overstocked must sell car parts hop-ups
Take advantage of this!
P.M. any real offers.
Take PayPal or Money Orders.
FREE immediate shipping in USA.
This is what's left:
I'll take bids for INDIVIDUAL BAGS OR the entire lot.
88637 orion 3D light flywheel 1 10.00
fm328-1 2 Spd collar M3 3 2.00
fm328-2 Washer collar 2 speed 3X12 mm 2 2.00
FM335-01 body mount upright screws 2 1.00
fm338BL Blue pivot ball screw caps 3 2.00
fm344c roll bar 1 4.00
FM346B Engine Motor Mount Alum 1 13.00
fm366 ft shock shaft 1 2.00
fm378 std side belts 1 3.00
fm424 shock piston set 1 5.00
fm429 4d flyweights 3 6.00
fm434 red 4d clutch shoe 2 10.00
fm530-2 rr shock shaft 1 2.00
fm538b Stock Front Belt 10 5.00
fm543-48 48 1st spur M3 2 4.00
fm543-49 49 1st spur M3 1 4.00
fm544-44b 44 2nd spur M3 5 4.00
fm601 Fr Knuckles 0 degree 4 4.00
fm602 rear uprights Hub set 4 3.00
fm609 servo saver set 3 3.00
fm610 center bulk set 1 2.00
FM611 battery plate & Spring cup holder set 7 4.00
fm612 small parts set 3 1.00
fm615 2 Spd shoe set M3 5 5.00
fm620 brake pad long screws 1 5.00
fm621 rear body mount post 1 1.00
fm622 2 speed holder & set screw M3 2 5.00
fm627 Ft upper suspension shaft 4 5.00
fm632 Top Plate radio tray 1 20.00
fm644 long wheelbase (Collari) arm set 1 9.00
fm646 2 speed holder & c clip EVO 1 5.00
fm648 Main Trans shaft 2 5.00
fmw25 M3 and EVO SP Low friction Front Belt 1 5.00
FMW645 front upper susp shaft for long wheelbase Collari arm set 1 5.00
fmw8b SP side belts 4 6.00
IFW330 M3 and EVO brake pads 4 10.00
la43 5.8 ball ends 4 2.00
spw5 turnbuckle set 1 3.00
UM112 4.8 ball end caps 2 2.00
vz091 3d weights 4 6.00
vz092 3d clutch bell 2 7.00
vz096 3d flywheel 1 6.00
vz099 clutch collar 2 1.00
vz102b Servo Saver Set Collari Evo set up 2 3.00
vz109 shock collar BLUE 4 2.00
vz221 5mm post 1 2.00
w5015 shock ball end 18 1.00
w5017 soft membrane 3 2.00
w5105BL shock cap BLUE 2 4.00
w5107 shock rebuild o ring set 3 3.00
w6006 hc membrane 4 2.00
OPEN BOX EVO conversion KIT Everything except chassis 1 80.00
Thanks,
Paulie
917-569-9091
personal email: [email protected]
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 07-18-2010, 09:29 PM   #786
I'll take bids for the entire lot.
Thanks,
Paulie
917-569-9091
Hey Paulie!
not selling any empire parts???
I'm looking for the following:
EMP2851, 2859, 2881, 2900, 2903 & 2906.
thx
MH
Old 07-19-2010, 05:52 PM   #787
Paulie Bee's Avatar
Hey Paulie!
thx
MH
You have P.M.
Thank You...
PT RC Racing Oils
Old 07-29-2010, 07:54 AM   #788
Thanks,
Paulie
917-569-9091
Pauli, I am interested in the conversion kit less the chassis. Do you still have it? Will you be at the GLC? If so, bring it there!
David Lee
Indianapolis, IN
317-859-0596
davidl is offline   Reply With Quote
Old 07-29-2010, 07:58 AM   #789
Besides Kyosho red box, what other tires are recommended for this chassis?
Thx.
Contact John's BSR Tires in Hamilton, OH USA. They can fix you up.
Old 07-30-2010, 08:35 AM   #790
Erock's Avatar
I second that! Ask for Monti he will get you going.
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 07-30-2010, 10:06 AM   #791
Phone for John's BSR Tires is 513-829-5995
Old 10-05-2010, 03:33 AM   #792
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Hey Guys,
Got a few locals at my club makign a change for new year season, hows the Kyosho M3 with you all, currently i have been running Motonica P81, but find a fair bit of belt wear and rear end issues
How often or better yet hows the wear and tear? Also as we all have had, crash scene damage whats the worst, and what has been the best
Cheers
Frankie
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 10-05-2010, 07:33 AM   #793
ALLSPEED's Avatar
Originally Posted by Kodak Hodak View Post
Hey Guys,
Cheers
Frankie
I abslutely love my M3. I have had mine for two years. All of my rear end and 80% of the front end parts are original. Thats due to me having trouble in the sweeper. The belts seem to last a while. If you inspect the pullys after you run the car the belts could last a full season or more. The rear belt seems to not wear at all. Your side will be the first to go. The M3 is a tank out the box. Minor upgrades you may want but it's not needed. I have hit the wall at the end of the strait and it didn't break any thing. I have hit the wall a few times right on the front wheel and only broke the upper A arm. This is a solid chassis. I just converted mine to the evo. I will run it for the first time this weekend. Hopeing it will make me a little better at the end of the strait.
Kyosho evolva M3 EVO O.S. .21xzr? Xray NT1 murnan modded nova,Xray T3,AE T5, sc5m, b44.3,Tekno sc
Mugen 1/8 off road.Tekin esc's, smc batts, team powers motors a winning combination
ALLSPEED is offline   Reply With Quote
Old 10-05-2010, 03:45 PM   #794
Hey Guys,
Cheers
Frankie
There is a reason this car won the last IFMAR WC, and it is more than just the driver. The previous post talked about durability, and it is true. My performance was greatly improved when puting this car on the track. Ran the EVO version some this year and didn't find much improvement over the original M3. Some top drivers feel the clutch is not the best, but I like it. Two speed on the EVO is an improvement. The EVO also allows a better mesh between pinions and spurs. Ran my car with short wheelbase both front and rear. Good luck.
Old 10-05-2010, 04:14 PM   #795
Hey Guys,
Great news on the feedback, yeah no doubt its a world champion car, always liked the Kyosho just never went with one in the first place, me thinks a kyosho for birthday is coming
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho Evolva duneland R/C Items: For Sale/Trade 9 07-28-2005 12:39 AM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
