Old 09-26-2009, 09:56 AM   #616
Erock's Avatar
Originally Posted by dameetz View Post
Anybody?
If you need more steering, move the scrub shims in the front to the outside of the knuckle.
"Scrub - Changing the shims on the rear axle to change width/scrub is mainly used to generate steering - If you use all shims on the outside, you create more steering but you also will hurt the rear tires as the car slides more. I normally try to run 1 shim outside and 3 shims inside so I can keep sliding and tire wear to a minimum." Josh Cyrul
As far as a set-up, what would you like? Easy to drive, lots of traction? What is the track like where you are racing? Is it slick, or has good grip?
Let me know and I can send you a setup tonight.
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 09-26-2009, 10:01 AM   #617
Erock's Avatar
[QUOTE
BTW I ll be using Zytec and P909 body, which body position will be good for these bodies and from where do you measure it?[/QUOTE]
You measure from the front of the bumper to the leading edge of the body. I run the 909 and I have it anywhere from 11mm to 15mm. Never tried the Zytec.
Old 09-26-2009, 11:00 AM   #618
dameetz's Avatar
Thanks for the info Erock. My local track has medium grip but I ll be racing first time with this car at my neighboring country which they said will be resurface soon so I m guessing that that it has good grip.
About the body, the more i put it forward the more steering I will get?
BTW will MRX4 one piece engine mount fit in this car?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 09-26-2009, 04:02 PM   #619
Erock's Avatar
Yes on the body.
I don't know for sure about the engine mount...
I'll send you a set-up that should be easy to drive and you can go from there.
BTW what clutch are you running? 4D? 3D?
Old 09-26-2009, 06:55 PM   #620
dougday's Avatar
Default 4D Clutch
What is the part number for the 4D Clutch assembly?
dougday is offline   Reply With Quote
Old 09-26-2009, 08:33 PM   #621
Paulie Bee's Avatar
Hello Doug:
Long time no see my friend! How is my favorite island?
I believe the complete 4-D part it is FM428
I actually have a complete 4D set brand new that came with my EVO Kit and I'll even throw in an additional new 4D clutch shoe for $35.00 total for you.
I have been running the 3D so I didn't use it.
You pick up the shipping charges unless you have someone flying down... Let me know.
Paulie
p.m. me if you wish to discuss.
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 09-29-2009, 04:49 PM   #622
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Paulie Bee View Post
Hello Doug:
Paulie
Paulie Good Luck @ the Novarossi race this weekend
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-30-2009, 02:49 AM   #623
KWT-NITRO's Avatar
hi guys,
just a small question, what 3D clutches are you using and why not use the 4D clutch included?? is the 3d clutch better than the 4d??
are .12 size engine clutches work on the .21??
cheers
Ali
Team Kuwait, Team Terribles, www.rccck.org
Kuwait National Champion
FEMCA Truggy Finalist & FEMCA Buggy Semi-Finalist
Thanks to all my sponsors: Modelix/Ultimate Racing, AKA Racing, AVID Racing, Stick-it1 Racing and HES
KWT-NITRO is offline   Reply With Quote
Old 09-30-2009, 10:21 AM   #624
Erock's Avatar
Originally Posted by KWT-NITRO View Post
hi guys,
cheers
Ali
I use the Orion lightweight flywheel with the Kyosho 3D shoes. It's alot lighter than the stock 4D.
Not sure about the 1/10 stuff. Paulie might know that one?
Old 09-30-2009, 11:17 AM   #625
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I do not race 1/8th, but I much prefer the 2d clutch with 4 flyweights. I believe that makes a 4d clutch. I use that a lot more than the 3d clutch and I have a few of both.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-01-2009, 03:14 PM   #626
Paulie Bee's Avatar
Hello Scott:
I think you meant a 4D clutch with 2 flyweights. I've tried this configuration. The end result is that I would have allot more slipping throught the power band because the two weights can't hold the pressure plate long or hard enough based on the spring and tension I use for high bite tracks. Biproduct of this effect is poor fuel milage and less performance. Honestly I suggest running either clutch stock. You need to try both 3D and 4D and decide which is right for your application. Hope this helps.
Paulie B
Thank You...
PT RC Racing Oils
Old 10-01-2009, 03:18 PM   #627
Paulie Bee's Avatar
Thanks George. Lets hope for good weather in New England!
Thank You...
PT RC Racing Oils
Old 10-01-2009, 06:11 PM   #628
Hello Scott:
Paulie B
No, I run a 2D clutch with 4 flyweights.
Old 10-02-2009, 05:40 AM   #629
Paulie Bee's Avatar
Default Clutchtalk
Hey Scott:
I misunderstood you. Are you saying that you are running the clutch that the two weights' hole originally sit on the two pins (swing out type) and substituted them with the 4 kyosho weights?
Thank You...
PT RC Racing Oils
Old 10-02-2009, 03:35 PM   #630
GMartinez's Avatar
Hey Scott:
Paulie I believe the clutch Scott's running is the 2D but you can add 2 more weights to make it a 4D the weights sit in between the pins like the 3D & do not swing out
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho Evolva duneland R/C Items: For Sale/Trade 9 07-28-2005 12:39 AM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
