Old 07-17-2009, 06:04 AM   #586
aaron_buran's Avatar
Originally Posted by kwilke View Post
aaron thanks for replying and answering my question but i have a few more to ask
whats different with the bulkheads and arms ?
whats different about the 2 speed ?
thanks in advance
The bulkhead molds for the front and rear don't appear to have changed, although for some reason my side belt is tighter with the stand gear ratio, so the layshaft may be closer to the rear axle, when I checked the parts prior to assembly the mold appeared to be the same. The rear a-arm has additional webbing in it for additional rigidity, the upper rear a-arm has been redesign for the new sway bar design. All of the plastic is now pulled out of a stiffer material, that looks and smells like the plastic that the old car was made out of, much high carbon content.
Since the car offers a new drive ratio (which you don't necessarily have to run, the old one will still work), the new 2 speed offers a wider range of gear choices to offset the higher rollout built into the car. The 2 speed has been redesigned with new gears, a new cam, new layshaft with a cross-pin, instead of a set screw, in an attempt to make it better and smooth. I have never had an issue with the transimission, so I decided to run all my old stuff (pulleys and gears) instead of buying all the new stuff at this time.
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 07-17-2009, 07:28 AM   #587
dameetz's Avatar
Will Futaba BLS451 good enough for steering? It has speed of 0.10 and torque of 10 kgs. What servos do you guys use for steering?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 07-17-2009, 10:28 AM   #588
Paulie Bee's Avatar
I have gone to KO Propo 2368 on both. A little steep but never an issue. U get what you pay for.
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 07-18-2009, 07:54 AM   #589
psycolosidude's Avatar
Default evolva m3 conversion
anyone know who has the best prices on the evo coversion? cheapest i found was 250.00
psycolosidude is offline   Reply With Quote
Old 07-19-2009, 10:53 AM   #590
Paulie Bee's Avatar
Call Richie at Brooklyn Hobbies. Evo Conversions in Stock. Tell him I told you to call re KYOSHO promotional pricing
Thank You...
PT RC Racing Oils
Old 07-19-2009, 11:15 AM   #591
Suspended
cool...
OILMAN is offline   Reply With Quote
Old 07-19-2009, 01:48 PM   #592
cool thanks ill do that
Old 07-20-2009, 03:03 PM   #593
I also purchased 2 BLS 451 servos for my M3, was that a good choice for throttle and steering?
Old 07-26-2009, 01:51 AM   #594
Send a message via MSN to boy_bee555
Im using BLS351 for steering and BLS451 for throttle
Kyosho RRR Evo + Novarossi Plus 12-5SCT + BLS451 +S9451
Kyosho Evolva M3 + O.S. VZ-R Version II + BLS351 + BLS451
Kyosho Inferno MP9 + GO engine + S9351 + BLS451
Futaba 3PKS 2.4
boy_bee555 is offline   Reply With Quote
Old 07-26-2009, 05:16 AM   #595
just wondering if you feel a difference from the BLS to the regular digitals, i was using the S9351 servos, didnt get a chance to run my BLS451 on the track yet due to weather, I also use the 3pks 2.4gigs, awesome radio
Old 07-26-2009, 05:22 AM   #596
any one have any comments on the new M3 EVO conversion, handeling differences or anything else, im ready to order it so i was just wondering what i should be expecting
Old 07-30-2009, 03:37 PM   #597
Maddin21's Avatar
The EVO definately is a step forward.
Especially in Europe we always had problems to let the car enter corners hard enough without making the rear end too lose.
Another problem was that cornering speeds had been to slow...
With the EVO entering corners is better (there's still room for improvements).
Much better are the speeds mid-corner to the exit...
Please look twice when installing the new rear-belt-tension-adjustment-parts.
There are some named 1&2 and others named L&R. Refer to the manual as installing the wrong one will make the belt sitting lower then the chassis. It's close enough with the correct ones. Use the hardest tension setting right from the start...all others are too lose...
The new gearbox workes well...and consistent with 2,3,4,... spur gears as the 2-speed bell always stayes the same...NICE :-)
Overall I like the car much better now...although it still not handles like the 2007...which was slower but so sweet :-)
Regards...MARTIN
Maddin21 is offline   Reply With Quote
Old 07-30-2009, 04:04 PM   #598
jt415gz's Avatar
Trader Rating: 29 (100%+)
Nice. If more people can share their experiences with the new EVO kit, it would really be helpful! Always like to hear more positive things about this car! =)
Thanks,
-jT =]
jt415gz is offline   Reply With Quote
Old 08-21-2009, 07:36 PM   #599
Default Kyosho m3 evo
Thanks for the tips Martin, The cornering and exit speeds are definatly improved and the gear box is sweet, I am definatly happy with the upgrade as it did improve on an already sweet machine. If any one has any comments on the evo let us know Thanks, and do look out for the 1&2 for the L&R wich Martin was right about or your belt will be sitting below your chassis
MOTONICA P8.0R///PICCO IDM///FUTABA 3pks///PROTOFORM
Old 09-05-2009, 12:06 PM   #600
dameetz's Avatar
My LHS just got the Evo conversion kit. I think I m going to get it. But they haven't got the spares for that like the new 2 speed gears, rear belt and pulleys. Does anyone know if mugen 2 speeds gear will fit there? As well as the rear belt and pulleys? I hate to wait for spares when I made the conversion, Mugen 2 speeds gears are readily available though.
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho Evolva duneland R/C Items: For Sale/Trade 9 07-28-2005 12:39 AM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
