Old 06-06-2009, 12:28 AM   #526
GREGORY!'s Avatar
rc rock,it;s better to find a latest model,even a used one.
it will be better from a 2005 car.
GREGORY! is offline   Reply With Quote
Old 06-06-2009, 08:41 AM   #527
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
rc rock if your looking for a nice kyosho m3 with a motor and pipe i will make you a deal, pm me if interested
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 06-10-2009, 05:27 AM   #528
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Default over steering
hello boys,
i am in need of a bit of help/ solution with my m3 .
it seem to over steer on power while steering . by which i mean is when i am steering on a slow Conner and apply power to get out of it , it over steers a lot. what can i do to stop over steering . on high speed turns the car is very stable though.
cheers
alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 06-10-2009, 10:15 AM   #529
Paulie Bee's Avatar
Default Mr On power oversteerER
Originally Posted by ccrcraceway View Post
hello boys,
cheers
alex
What toe and castor are you running now up front? In the mean time dial out some D/R on your radio a couple of clicks. PM me ...so as to not to clog-up the thread.
Paulie
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 06-10-2009, 12:00 PM   #530
hello boys,
cheers
alex
Make sure that the drive system to the front wheels is in god shape (belts pullies etc.) and that you have the correct pullies mounted for th eoverdrive chart you are using, if this is all good guessing you have low bite surface add a little overdrive.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 06-10-2009, 06:32 PM   #531
how do i add over drive? the drive train is good and new . all belts pulley etc.
Old 06-11-2009, 06:52 AM   #532
Simplest method is larger fronts - try 6mm split instead of 7.
Old 06-11-2009, 11:33 PM   #533
jt415gz's Avatar
Trader Rating: 29 (100%+)
Default Empire (Epmire)
EMP 2851 - what is that clear plastic tube used for?
EMP 2865 - what specific sized pivot balls and screws do I need to screw into the bars as it didn't come with any?
Thanks,
-jT =]
jt415gz is offline   Reply With Quote
Old 06-11-2009, 11:35 PM   #534
jt415gz's Avatar
Default Epmire
Edit: my bad for the double post RCTech is hating on the Nitro On-road forums tonight.
Thanks,
-jT =]
Old 06-12-2009, 07:31 AM   #535
Default ePmire, I like the new name!
I have to answer twice
Hi JT,
Question one: "2851 - what do I do with the clear plastic tube included?"
Cut into 1/8th "pucks". You will use the piece(s) you just cut between the set screw and the sway bar. It will allow you to have a tight grip on the sway bar, keeping it stationary, but still be able to adjust. Plus, it keeps the set screw from scoring the sway bar
Question two: "what size pivot balls and screws"
To connect the upper end of the rear bar assy I use
FM624
5.8mm FLANGED BALL - STD
LA43H
5.8mm BALL ENDS - HARD
Feel free to call if you have additional questions. 650-280-6095[/QUOTE]
Hi JT,
FM624
LA43H
Rich Browne is offline   Reply With Quote
Old 06-12-2009, 03:34 PM   #536
rpoage's Avatar
The small pieces of nylon are to be put into the two holes before the set screw so that the bar is not galled and so that you can have the option of snugging the bars and using a sway bar adjusting tool for on the fly adjustments.
As for the balls, sorry I for got they are not included with the bars any longer but the item you need is the short ball end.
Ashford Hobby-KYO UM129 4.8 Ball Stud (Short) (4PCS)
rpoage is offline   Reply With Quote
Old 06-12-2009, 04:42 PM   #537
jt415gz's Avatar
Hi JT,
FM624
LA43H
Gotcha'. I ended up using 5.8mm Flanged Ball (Long) with long enough set screws and adding good oh Blue Thread Locker.
BTW, I called your (650) number and left a message because I had a question about how to get the front belt to clear (I have The Tensioner M3 installed) the KYO FMW34 Alloy Adj Ack Servo Saver set?
Seems that the top of the Saver Nut (Stand Off) is too high and rubs against the belt quite a bit to ignore its safety. Mind you, that the Kyosho instructions for the KYO FMW34 was printed in 2004 and instructed to screw the supplied 3x12mm screws from underneath, up through the 5.8mm Flanged Balls (2) and then finally through into the threads of the chosen Saver Nut (which isn't possible at all to do with that Flanged Ball as one end only fits an Allen head. The above was just to clarify things in detail. I believe I will attempt to use a correct length Set Screw (longer) instead of the Button Head per the out dated instructions sheet. I ask because I seen a picture on the Empire website with an M3 chassis using the same KYO FMW34 and quite possibly in conjunction with The Tensioner M3. So how did you guys do it?
http://www.empirercracing.com/sway.html
Cool. Thanks but I used 5.8mm Flanged Ball as I already had them
Thanks,
-jT =]
Old 06-12-2009, 07:48 PM   #538
BTW, I called your (650) number and left a message...
I enjoyed our chat. Look forward to meeting you at the RAMS
Rich
Old 06-15-2009, 12:44 AM   #539
Robert R's Avatar
I am sure this has been asked but can not find it, are the part from older car work on the M3? If so anyone have a list of them? Thanks
Robert R is offline   Reply With Quote
Old 06-15-2009, 06:27 AM   #540
No list has ever been published but essentially the clutch,transmission,belts and pulleys and the shocks and springs.
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho Evolva duneland R/C Items: For Sale/Trade 9 07-28-2005 12:39 AM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
