Old 06-18-2008, 06:17 PM   #391
Scott Kimbrow's Avatar
Thank you occ, it was a very competitive and very fun race. Here are the answers to your questions...
1) no
2) no - not really any pictures. we had to leave as soon as the main was over to catch a plane.
3) yes - Ralph switched this year. I believe he is running one more 8th scale race this year; The ROAR Nationals (also at 301 Raceway).
Thank you again for the compliments,
Scott
Serpent / Serpent America / Novarossi / Spektrum / Xceed Tires / Tornado Fuel / Empire Racing / Protoform / Thunder Power / Avid Bearings / A-main Hobbies / Dynamite
Scott Kimbrow is offline   Reply With Quote
Old 06-19-2008, 09:46 PM   #392
THeGame's Avatar
Send a message via AIM to THeGame
Default Kimbrow
Nice run at the Capital. See you at the Nats... Think you can pull of a 3peat ???
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 06-24-2008, 04:39 AM   #393
Send a message via MSN to boy_bee555
Originally Posted by occ View Post
I do but dont have a scanner. Dont worry too much about this setting sheet. The english version is not really helpful either. Just keep reading this thread & or posting questions here.
Yes, they do make hardened gears:
FMW304-15 Hard 1st Gear (15T)
FMW304-16 Hard 1st Gear (16T)
FMW304-17 Hard 1st Gear (17T)
FMW304-19 Hard 2nd Gear (19T)
FMW304-20 Hard 2nd Gear (20T)
Do they make one for 21T? If there is, what is the part number? Does it suppose to be FMW304-21?
Also, I am looking for the 2-speed clutch tool. Will the VZW221 (2-Speed clutch tool) work with the Evolva pinion gears?
Kyosho RRR Evo + Novarossi Plus 12-5SCT + BLS451 +S9451
Kyosho Evolva M3 + O.S. VZ-R Version II + BLS351 + BLS451
Kyosho Inferno MP9 + GO engine + S9351 + BLS451
Futaba 3PKS 2.4
boy_bee555 is offline   Reply With Quote
Old 06-24-2008, 10:21 AM   #394
rpoage's Avatar
They don't make a 21t at this time.
The VZW221 is for .8 pitch/200mm cars and not for the 1/8th /.21 cars.
What you are looking for is the VZW040
Ahford Hobby / VZW040
rpoage is offline   Reply With Quote
Old 06-24-2008, 11:46 AM   #395
YBSLOW's Avatar
I beleive Team Titan makes a 21 tooth for the M3. www.RacedayHobbies.com
has them. Titan pinons are nice quality as well.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-24-2008, 12:07 PM   #396
Team Kamikaze's Avatar
YBslow is right Titan makes one.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-24-2008, 12:44 PM   #397
1fastdude's Avatar
Trader Rating: 15 (100%+)
Delta Manufacturing also makes hardened pinions that are very good, 15 thru 21 and possibly others too.
★RCAmerica •Xray •Hudy •BSR •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 06-26-2008, 01:13 AM   #398
Thanks everyone for info.
Futaba 3PKS 2.4
Old 07-09-2008, 03:06 PM   #399
Default Please i need help
Hello everybody.
My name is Guillaume, i'm from france ( please excuse my poor english)and i running with EVOLVA M3 since february 2008.
I was very easy with The EVOLVA 2005WC, and at the begining of the year with M3, but now i become to be loose in the set up.
I need help , because i have a lot difficulties with my car, more now with track temp increasing.
The rear is sliding,no traction, and not a lot of steering, so a bad car.
I am using Centrale Body ( as about 95% of french drivers ) but i'm not sur of the body position ( 15mm or 10 mm ????)
I'm running with long whell base ( is not good for steering)
etc...
I read the set up sheets plublished on the forum and the setup is very far from Kyosho standart set up and mine?
Can you explain me some items as:
Sus Older part "C" ( i use B)
Upper Arm height ( i use 3mm)
srcub set front and rear ( i use 1mm)
Upper Arm (in or out )
If someone can give me some explanations or how and where to find it
Thank for your help
GUPA is offline   Reply With Quote
Old 07-14-2008, 07:21 PM   #400
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Arrow where to buy
where is a good place to get m3 stuff online ? and where can i purchase the alloy or harden pinions.
cheers alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 07-14-2008, 08:12 PM   #401
nitrodude's Avatar
Go to this website http://kamikazetoysandhobbies.com/home.htm, very good customer service. If the parts you need are not online, give them a call, they have most parts for the M3 in stock.
1-714-997-TOYS
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-20-2008, 03:56 PM   #402
TTT...
Also wondering if there were any Factory A-main guys (or someone with info) which attended the Great Lakes Challenge, if they wouldn't mind sharing their set-ups
Much appreciated
Awesomatix USA, AVID, Serpent USA / Desoto Racing, Team Scream, LRP, Psycho Cells Racing, Sweep Racing, T.Q. Wire, Hurricane Motorsports, Core Creations, Hobbytown USA of K.C., 2mm Design and ProLevel
BSYDOR is offline   Reply With Quote
Old 08-20-2008, 05:01 PM   #403
Hi BYSDOR-
If you look up at post #395 in this thread, you will see my setup from the Capitol Classic. I ran the exact same setup at the GLC with just one difference. I used 40 shore rears at the GLC instead of 37 shore.
Hope this helps!
Scott
Old 08-21-2008, 03:24 PM   #404
Thanks for the info Scott.
I have some more questions if you don't mind- for the rear upper arm height on the hub (doesn't appear to be on the set-up sheet, no spot for it), how many millimeters shims? And I am seeing the width for the rear is 258, with red box tires? Seems really narrow- did that help with side bite, or reduce it?
Regards,
Bill
Old 08-22-2008, 12:40 AM   #405
gansei's Avatar
Default M3 video
i uploaded some Evolva M3 video in YOUTUBE.
this circuit is korea local "Kirina Circuit"
it had same layout as japan BOSS CIRCUIT.
http://kr.youtube.com/watch?v=IZK4GnRO5bM
http://kr.youtube.com/watch?v=uScZM8VKIug
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho Evolva duneland R/C Items: For Sale/Trade 9 07-28-2005 12:39 AM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
