Old 03-13-2008, 01:38 PM   #301
Finally had a chance to do pure assembly work on the M3 and just like numerous others have mentioned partially pre-tapping the bulkheads looks like the hot tip (especially the 4mm screw right near the brake cam- pretty much tapped this all the way to prevent a potential bind issue), everything seems to fit well, looking forward to turning a wheel at the end of the month.I realize I'm not adding any earth shaking information - just thought I'd get our M3 thread off page 3!!
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - IGT8 2017
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 03-13-2008, 02:27 PM   #302
aaron_buran's Avatar
Your going to like the car Rick, did you order a V-one app brake pad set?
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 03-14-2008, 06:26 AM   #303
Guys,
When using a Lipo rx pack... Is a voltage regulator REALLY neccessary?
[FONT="Arial Black"][SIZE="2"]team kyosho / empire racing / speedmerchant / ko propo / novarossiusa.com / phat skeems paint works / 301 raceway [/SIZE][/FONT]
NitroHead is offline   Reply With Quote
Old 03-14-2008, 06:36 AM   #304
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by NitroHead View Post
Guys,
Only if you don't want to risk damaging your electronics.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-14-2008, 06:56 AM   #305
Ordered a couple from reading about your experience, also have some high metal content car material glued up along with another experiment that I've had in the back of my mind for a while.
Old 03-14-2008, 09:55 AM   #306
I am sure the skunkworks lab at empire has been busy since the annoucement of the new car.
Old 03-14-2008, 10:25 AM   #307
Scott and Jim have already tested the new front hangers and sway bar mounts and they will be ready to ship soon.
Old 03-14-2008, 07:02 PM   #308
GSwayze's Avatar
Aaron, what's the part number on the V-One app brake pad set?
GSwayze is offline   Reply With Quote
Old 03-14-2008, 07:59 PM   #309
Ditto
apex racing is offline   Reply With Quote
Old 03-14-2008, 08:54 PM   #310
APP02-2 V-One App Brakepads (out of stock)
APP02 V-One App Brakeset (includes rotor but is in stock, when I checked at the begininng of the week)
When you install these they are thinner so you have to tighten the screws that support the pads down more, I took a few coils off the springs too, (that may not be necessary)
Old 03-14-2008, 09:54 PM   #311
Thanks Scott,
Im told it may work well for a while but would eventually fry the reciever or servos or both. Regulator it is!
Old 03-17-2008, 10:25 PM   #312
rjr
I think it definitely helps cutting the springs with the APP brakes. The brake lever was a little notchy without cutting them.
rjr is offline   Reply With Quote
Old 03-18-2008, 06:22 AM   #313
Wierd, did you tap the screws in the bulkhead? If not and you use the long screws (from the chassis to the bulkhead) per the instructions, you probably need to ream the brake cylinder hole. The first one I did, I did not tap the screw holes and I used the long screw there and had the notchiness you describe, which was actually the cylinder binding in the bulkhead IMO. I used a short screw only on the hole nearest the cylinder. What made this problem difficult was the notchiness was intermittant, it would do it... and then not do it. Until we redid it all, and/or reamed that hole, nothing made it go away. I didn't think the tension had anything to do with it, I actually thought more tension would have been better. I know Toso had some green springs on his pads, I have no idea where the Sirio guys got them when they build his car, I will try to find out and let everyone know.
Old 03-21-2008, 09:38 PM   #314
WOW!!!
Jim, Aarron and Rick, followed your advice and putting the M3 together has been a pleasure. The build is super easy and the new platform is the usual kyosho super high quality! No binding anywhere.
Now I just need someone to do my wiring!!!
Old 03-21-2008, 10:04 PM   #315
carkillaii's Avatar
Aaron I think the springs there using are 12th scale front springs I think
carkillaii is online now   Reply With Quote
Kyosho Evolva 007 lifeguy R/C Items: For Sale/Trade 12 08-21-2008 08:40 PM
1/8th Kyosho Evolva 05 DJ Clu R/C Items: For Sale/Trade 14 10-22-2007 01:17 PM
kyosho evolva speedjunkie R/C Items: For Sale/Trade 0 03-25-2007 04:52 PM
Kyosho Evolva duneland R/C Items: For Sale/Trade 9 07-28-2005 12:39 AM
Kyosho 1/8 Evolva NIB Jspecrcr R/C Items: For Sale/Trade 2 09-16-2004 07:37 AM
